Old Tue, Oct-09-2018, 03:45:30 AM   #41
M3AZ
///M3AZ
M3AZ's Avatar
Reputation: 0 M3AZ is on a distinguished road
Default Re: Chach's DIY Porsche 996 BBK Conversion extensive write up
I just bought some used 996 calipers for this project. Anyone know if 17” wheels work with this setup?
██████████████████ 2003 E46 M3
Old Tue, Oct-09-2018, 03:53:02 AM   #42
umichchris
Reputation: 0 umichchris is on a distinguished road
Question for anyone who may know, I bought these front pads based on suggestions in this thread. Obviously they don't/won't fit with those clips on the back. Do people just cut those off so they can slide into the slots? (Sorry if that's a dumb question)
Thanks!
Jump to top umichchris is offline   Reply With Quote
Old Tue, Oct-09-2018, 04:15:34 AM   #43
CSLM3Wannabi
Thanks!
Those are the wrong pads. The fronts are suppose to be EUR917 and the backs should be EUR737.
2005 BMW M3 ZCP Nardo Gray | ESS VT2-550 | Dinan Throttle Bodies | 6MT Swap | Active Autowerkes Headers + Section 1 w/ 100 cells | Miltek Section 2 and 3 | KW V2 w/ GC camber plates and Eibach Front and Rear Swaybars | Porsche 996 BBK upgrade w/ OEM ZCP rotors | Umnitza V4 Angel Eyes | Euro bumper w/ Morimoto led fogs | 1 piece Carbon Lip | VIS XTS Full carbon hood | SCZA Carbon Fiber CSL Trunk | Carbon Fiber CSL Diffuser | Square ZCP Wheels |
Old Tue, Oct-09-2018, 05:17:32 AM   #44
HassanEido
HassanEido's Avatar
Lebanon
Thanks!
those are the pads for the OE brake calipers..what are you trying to do?
On the Porsche bbk, u will need the front pads form a 2.7L Porsche boxster
U will then need to remove the metal inserts and might have to grind the metal from the bottom till it's flush with the pad material(depending on your carrier, it might not be necessary).
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Tue, Oct-09-2018, 05:51:13 AM   #45
umichchris
im doing the full 996 caliper conversion. im actually 50% through the process and was double checking my parts this weekend. when i opened the box, i realized the pads looked like they definitely werent going to fit.
i will take a look at the EUR917 pads online (as suggested by the other reply). maybe i can return these for a swap...
Old Tue, Oct-09-2018, 06:03:07 AM   #46
HassanEido
HassanEido's Avatar
Lebanon
These are E46 m3 pads(wont work). U need the front pads from the 2.7 Liter boxster for ur rears man
https://www.ecstuning.com/b-genuine-...t/98635193915/
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Sun, Oct-21-2018, 11:27:22 PM   #47
Hunterphoto
Hunterphoto's Avatar
Reputation: 0 Hunterphoto is on a distinguished road
Default Chach's DIY Porsche 996 BBK Conversion extensive write up
Hey guys I need some help. Iím really glad this thread has come back alive since the beginning but I bought my 04 M3 with a BBK installed using OEM 996 calipers (confirmed by parts number) the owner before me was clueless to say the least and has no information for what he did or receipts for the kit. I bought new OEM ZCP rotors, and 996 pads for the front. When I installed the pads this was the result which is what the original problem was from the previous owner using non ZCP rotors and some kind of pad. I donít know what the deal is or why itís not fitting properly. Someone help please...
Jump to top Hunterphoto is offline   Reply With Quote
Old Sun, Oct-21-2018, 11:56:59 PM   #48
CLAWHAMM3R
BELOW M3
CLAWHAMM3R's Avatar
Reputation: 0 CLAWHAMM3R is on a distinguished road
Are the calipers machined?
2004 ///M3
Jump to top CLAWHAMM3R is offline   Reply With Quote
Old Sun, Oct-21-2018, 11:58:14 PM   #49
Hunterphoto
The previous owner installed the kit and gave me no info about it.
Old Sun, Oct-21-2018, 11:59:05 PM   #50
Hunterphoto
Discussing Chach's DIY Porsche 996 BBK Conversion extensive write up in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
