Old Fri, Jan-26-2018, 05:47:15 PM   #31
Default Re: Chach's DIY Porsche 996 BBK Conversion extensive write up
How about slotted or drilled, or both, Stoptechs. Should be about $150 for a pair of rears. The weight savings from semi-floating euros to stoptechs isn't that huge and doesn't do much being in the rear anyway. Fronts would be more important IMO.
Looks like prices went up a bit, used to be $75-80 a pop, now over $100:
https://www.tirerack.com/brakes/brak...4&autoModClar=
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · zero options · <3200lbs · JOURNAL
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 S pipes 2.5" · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pullies · fan/SAP/washer/fog delete · CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs · Hotchkis front sway (med) · rear strut bar · TMS camber & subframe plates · Eibach alu rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · OE weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing
OE CSL trunk · Cobra Nogaros + BK + manual OE bases · TMS black pedals · Sportline 8S 18"x 8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL · ZHP "712" rack · Pioneer/CDT/Eclipse/Kicker
Old Wed, Jul-04-2018, 07:38:02 PM   #32
umichchris
Reputation: 0 umichchris is on a distinguished road
looking for info on which brake pads to order...
i need to order front & rear pads as my BBK is almost ready to install. ive got the p0lar rear brakets....from what ive read here & there i should order a specific sized rear pad too in order to avoid the rust ring right?
last question, any pads for Porsche calipers that are low-dust like the Hawk HPS ones? thanks all!
Jump to top umichchris is offline   Reply With Quote
Old Wed, Jul-04-2018, 07:59:29 PM   #33
Bbk and low dust? Noooooooooo
Old Wed, Jul-04-2018, 08:13:15 PM   #34
umichchris
i mean, its just a 996 C2S BBK....i figured someone had made some low dust pads for Porsche owners by now just like they have for BMW ///M owners no?
Old Wed, Jul-04-2018, 11:07:15 PM   #35
robgill
I'd rather be at the track.
robgill's Avatar
Reputation: 0 robgill is on a distinguished road
I use these for street pads, no dust and no squeaks:
Tirerack Akebono EUR918
Tirerack Akebono EUR917
My '02 E46M Build Thread
Jump to top robgill is offline   Reply With Quote
Old Thu, Jul-05-2018, 02:29:10 AM   #36
umichchris
thanks for the suggestion, but it looks like these are pads for BMW calipers and rotors.....not Porsche 996 911 Carrera calipers and rotors...
Old Thu, Jul-05-2018, 06:15:41 AM   #37
whips333
whips333's Avatar
Subscribed
Old Thu, Jul-05-2018, 06:18:30 AM   #38
Kyle90
Reputation: 0 Kyle90 is on a distinguished road
Those are correct for 996 calipers. Not sure what you’re looking at.
Jump to top Kyle90 is offline   Reply With Quote
Old Thu, Jul-05-2018, 06:34:13 AM   #39
umichchris
One does link through to Porsche pads, the other is for a BMW pad set-up seemingly, both sets of pads should specifically fit the Porsche calipers right?
Just to makes sure I'm not getting confused, please see the attached screen grabs of what I see after I click-through both links. Thanks!!
Old Wed, Sep-12-2018, 04:51:47 PM   #40
ftapache
ftapache's Avatar
Reputation: 0 ftapache is on a distinguished road
subd for info
Revival Journal
Jump to top ftapache is offline   Reply With Quote
Discussing Chach's DIY Porsche 996 BBK Conversion extensive write up in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
