Old Mon, Jun-22-2015, 10:34:59 PM   #21
ILLuSioNz X
Built, not bought
ILLuSioNz X's Avatar
Reputation: 0 ILLuSioNz X is on a distinguished road
Default Re: Chach's DIY Porsche 996 BBK Conversion extensive write up
Originally Posted by chatcher View Post
Those ECS rotors look like a great alternative to some of the more expensive ones out there. How are they on the track?
-Chauncey
2003 E46 M3 COUPE
Engine/Transmission: "Bolt-on's"
Wheels/Tires: 18 TE37SL & Falken RT615K
Suspension: TRM Coilovers 780F/895R|OEM Front & Turner Rear Reinforcement Plates|RE Rear Spring Perch Reinforcement|GC Race FCABs|GC Monoball RTABs|Godspeed LCAs|Turner Monoball Upper CAB|Turner Sway Bars|Turner Subframe Reinforcement (installed by Coinage)|Turner Solid Subframe, Differential, Motor and Transmission Mounts
Braking: Rotora 4-Piston Calipers|S/S Lines|Ate Dot4|Powerslot Rotors|Ferodo DS2500 Brake Pads
The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS)
Jump to top ILLuSioNz X is offline   Reply With Quote
Old Fri, Jul-17-2015, 08:05:04 PM   #22
crazyseaman
chris chach
Reputation: 0 crazyseaman is on a distinguished road
bump install instructions on post#2
themeetspot.info
Like me on facebook for NY events, and rollout info
CHACH:
2002 E46 M3 VERT (NEW PROJECT)
1987 E30 325iS (DAILY DRIVER)
1992 DA INTEGRA (SOLD)
Jump to top crazyseaman is offline   Reply With Quote
Old Sat, Oct-10-2015, 09:44:53 PM   #23
UrLuzn
ImaLuzr
Reputation: 0 UrLuzn is on a distinguished road
I just completed front brakes. I like the feel and looks of the brakes that I have decided to do the rear brakes asap. I have already ordered the rear calipers.
Did I read it right my rear rotors on my 04 M3 will work?
I have a question. What did you torq the 996 adapter & the caliper to the adapter?
Jump to top UrLuzn is offline   Reply With Quote
Old Sun, Oct-11-2015, 09:09:35 PM   #24
Teigland
Teigland's Avatar
Reputation: 0 Teigland is on a distinguished road
Norway
all the e46m3's uses the same dimensions for the rear rotors, the us got cheap 1 piece steel rotor while euro/csl (and us zcp?) uses semi floating rotors with aluminium center hats, but they are all 328x20mm and that is what the kit is meant to use. so yeah, oem rotors can be used, but best result is achieved with new rotors and pads at the same time.
also reduses bead in time and chances of squeling etc due to uneven rotor surface that does not match the new pads.
Aspirering Scandinavian Drifter!
Jump to top Teigland is offline   Reply With Quote
Old Mon, Aug-07-2017, 03:28:02 AM   #25
khangm3
Reputation: 0 khangm3 is on a distinguished road
Awesome
Jump to top khangm3 is offline   Reply With Quote
Old Mon, Aug-07-2017, 03:35:13 AM   #26
drp2014
Add Lightness
Reputation: 0 drp2014 is on a distinguished road
Wow, brought this thread back from the dead
Upcoming projects: EVOLVE carbon roof, Interior surprise
Services: Valve shim kit for rent, Valve adjustment in Virginia/North Carolina
Jump to top drp2014 is offline   Reply With Quote
Old Mon, Aug-07-2017, 05:47:56 AM   #27
khangm3
Haha yes, I commented in cause I'm currently doing this project and using some of his part list as reference and a gauge for price
Old Tue, Sep-05-2017, 02:44:05 PM   #28
rpearl555
So Shiny So Chrome
Can the photos be reuploaded?
Old Tue, Sep-05-2017, 08:40:57 PM   #29
binary
Reputation: 0 binary is on a distinguished road
It's posts like this..when my I remember just how angry I am at PB for ruining the internet.
Jump to top binary is offline   Reply With Quote
Old Fri, Jan-26-2018, 05:43:58 PM   #30
umichchris
Reputation: 0 umichchris is on a distinguished road
been using this thread as my guild book while putting together my own 996 BBK...
one quick question, anyone out there try the other rear rotor options?
im leaning towards the OEM CSL rear rotors....but i love the 'bling' look of the ECS Tuning 2-Piece rotors, but $700 for rear rotors when the fronts are only $530 seems like highway robbery.
$336 Rear OEM: https://www.ecstuning.com/b-genuine-...282303304~oem/
$700 Rear ECS 2-Piece: https://www.ecstuning.com/b-ecs-part...0/011699ecskt/
any other options out there i may have overlooked?
thanks!
Jump to top umichchris is offline   Reply With Quote
Discussing Chach's DIY Porsche 996 BBK Conversion extensive write up in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
