Old Tue, Jun-11-2019, 04:55:40 PM   #11
Trans3900
Reputation: 0 Trans3900 is on a distinguished road
Default Re: SMG Leaking Fluid
Originally Posted by TangkYou View Post
Update: Replaced the clutch slave cylinder and everything is back to normal. Thanks for the help! For anyone who has a similar problem my symptoms were popping out of gear after driving 100 meters. The SMG would prime but it would lose pressure. Restarting the car will allow you to put it into gear again and pop back out after 100 meters. If your SMG fluid keeps running low i would look under your car to find the clutch slave cylinder and see if it is leaking. If it is you will probably need to replace it. Hope that helps!
The thread is from 2014 and Tang was last seen here in January. Doubt you'll hear from him.
Yes , Thanks i noticed that, it might be worth the shot lol but i least i ll be checking that slave cylinder see if that something to do with my issue
Jump to top Trans3900 is offline   Reply With Quote
Old Tue, Jun-11-2019, 05:11:36 PM   #12
Trans3900
Originally Posted by jdamore44 View Post
Thank you i will go over them as soon as i can
Old Tue, Jun-11-2019, 06:03:14 PM   #13
SMG cog light
Leaking internal clutch slave cylinders can be repaired with a kit and do not require that you buy a brand new unit. It's from the O ring inside the cylinder or the boot.
fcpeuro sells it or ecstuning. You can also find the kits on amazon or ebay.
https://www.fcpeuro.com/products/bmw...-21521159332-1
https://www.ecstuning.com/b-genuine-...AaAhSOEALw_wcB
Here is the DIY thread.
https://forum.e46fanatics.com/showthread.php?t=979825
Jump to top SMG cog light is offline   Reply With Quote
Old Tue, Jun-11-2019, 06:58:01 PM   #14
Trans3900
[QUOTE=SMG cog light;1067965194]Leaking internal clutch slave cylinders can be repaired with a kit and do not require that you buy a brand new unit. It's from the O ring inside the cylinder or the boot.
Great info , Thanks again i will keep you inform of the results
Discussing SMG Leaking Fluid in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
