Old Mon, Jun-03-2019, 03:29:47 PM   #31
Trans3900
Reputation: 0 Trans3900 is on a distinguished road
Default Re: HOWTO: SMG Accumulator Pressure Test
Originally Posted by SMG cog light View Post
1. Are you saying that you have both the top and the bottom resistor on at the same time?
2. And if you put a 10,000 ohm resistor, you need to remove that ASAP 1,000 is plenty and 3,000 is already too high. Doing a resistor mod will make your motor fail prematurely also. 10K resistor; That will literally kill your motor. The max pressure that the pump builds is also dependent to the hydraulic fluid temperature. The accumulator is what holds the pressure that is built up by the pump. Right now you are not building sufficient pressure. That is not an accumulator problem. That is either a dead/failing motor or that resister.
3. Do the live data readings again after you removed the 10k resistor.
Thanks, and yes i will removed the 10k resistor and run live data, one quick question should i ran the data with engine on or off or both? I'm out of town right now but Friday that i get back to town i will be running the test and keep you updated. Thanks Again
Jump to top Trans3900 is offline   Reply With Quote
Old Mon, Jun-03-2019, 10:19:37 PM   #32
SMG cog light
I actually responded to you in this thread about the SMG pressure drop and time. Post #29 down.
http://www.m3forum.net/m3forum/showthread.php?t=606540
Hi. yes. but that video says while driving. The pressure decay is different without shifting. Was just wondering if you had the time for the normal decay without shifting.
Jump to top SMG cog light is online now   Reply With Quote
Old Mon, Jun-03-2019, 10:22:06 PM   #33
SMG cog light
i usually run the live data with engine on and the car at normal operating temperature. If your fluid is cold and the engine temp/oil temp is not at it's normal operating temperature then it's not accurate. Because when the fluid gets hot is when you develop problems with the smg.
Old Tue, Jun-04-2019, 01:20:07 AM   #34
Trans3900
Thanks for the info. I have I lot of testing to do.
Old Tue, Jun-04-2019, 01:54:31 AM   #35
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Default HOWTO: SMG Accumulator Pressure Test
It was down in Post #32
Ok with the car COLD and OFF the accumulator went from 65 down to 48 Bar before turning the pump ON. Elapsed time was 6:00 minutes.
I just ran a test with DIS. Car was cold, although in sitting in 85 degree garage. Battery was kinda low but hooked up to a charger.
Old Tue, Jun-04-2019, 05:42:14 AM   #36
SMG cog light
Thanks for the info. 6 minutes and accumulator psi of 30. Seems your accumulator is reaching the end of it's life.
How does the car run? Does it throw cog light on very hot days?
How many miles do you have on the car?
Did you do any mods like pump relocation, burkhart fluid and new motor or temp sensor? or is everything original and pump in original location?
I'm trying to gather data from the community regarding pressure decay. thanks again.
Old Tue, Jun-04-2019, 01:46:19 PM   #37
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
No
130K
No mods, all stock.
Iíve owned this car for approx 4 years now. Iíve never had a SMG issue even thru 3 hot summers. Temps are 100-120 during the summer and this is my daily driver. Iím running ceramic coated headers, vented hood and a Spal electric fan with the Aux Fan.
Old Tue, Jun-04-2019, 09:00:17 PM   #38
Trans3900
How can i get DIS to run this Test?, I have INPA but i dont think is running that well or if you guys have some other software that i should use will be greatly appreciate it
Old Thu, Jun-06-2019, 08:17:06 PM   #39
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
I will PM you.
Old Tue, Jun-11-2019, 04:57:43 AM   #40
Trans3900
I will PM you.
Thank You
Discussing HOWTO: SMG Accumulator Pressure Test in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
