Old Sun, Jun-02-2019, 06:21:56 AM   #21
Nambo
Reputation: 0 Nambo is on a distinguished road
Default Re: HOWTO: SMG Accumulator Pressure Test
Good info. Another damn thing to add to the list
Jump to top Nambo is offline   Reply With Quote
Old Sun, Jun-02-2019, 08:55:25 AM   #22
SteveEvans
Reputation: 0 SteveEvans is on a distinguished road
United Kingdom
What does <F6> Activate do?
Steve
Jump to top SteveEvans is offline   Reply With Quote
Old Sun, Jun-02-2019, 09:09:52 AM   #23
SMG cog light
Shift and F6
E46 Transmission and M-Gearbox
F5
This only shows the pressure of the smg pump that is built up by the electric motor in bars (45-80 bars in smg 2) It doesn't show the pre-charge of the nitrogen inside the accumulator in psi. (29-41 psi good accumulator) anything less than 29 is defective and needs to be replaced.
Jump to top SMG cog light is online now   Reply With Quote
Old Sun, Jun-02-2019, 09:10:58 AM   #24
SMG cog light
Steve
Activate will allow you to manually turn the electric motor of the pump on and off to prime up pressure.
Old Sun, Jun-02-2019, 10:24:26 PM   #25
Trans3900
Reputation: 0 Trans3900 is on a distinguished road
Would you say this pressure values look ok to you? My pressure goes to 46 the most and then goes down to zero. When can we say an accumulator is bad? also i have to mention i have done the up resistor and the bottom
the up is with an 680 resistor didnt do a thing to my shifting , keep going from 1 and R to N after maybe one min. at the bottom i have a 10k resistor
worked for a while the night i did the installation then next morning it didnt switch gears at all. any advices or tips you can give me
Note
what i have replaced so far
1. Smg Motor
2. Salmon Relay
3. Cooling level 2
Jump to top Trans3900 is offline   Reply With Quote
Old Sun, Jun-02-2019, 10:50:39 PM   #26
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Here is a video of my SMG pressure while driving. The lowest pressure is still higher than yours. I would say you have a bad accumulator but Iím no SMG expert.
Old Sun, Jun-02-2019, 11:49:26 PM   #27
Trans3900
Afrer seing your vidieo, i came to my conclutions that i should change my pressure Accumulator. I dont even get to drive the car my pressure doesnt hold or goes any near 50. thank again for your video, now does anybody has the DIY for the Pressure accumulator and i should change the temp Sensor on the SmG since it will be easier to do is that correct ? Btw. I think the low hydraulic temp is due to the resistor Mod
Old Mon, Jun-03-2019, 01:25:18 PM   #28
SMG cog light
Originally Posted by Trans3900 View Post
Attachment 215792
Note
1. Smg Motor
2. Salmon Relay
3. Cooling level 2
1. Are you saying that you have both the top and the bottom resistor on at the same time?
2. And if you put a 10,000 ohm resistor, you need to remove that ASAP 1,000 is plenty and 3,000 is already too high. Doing a resistor mod will make your motor fail prematurely also. 10K resistor; That will literally kill your motor. The max pressure that the pump builds is also dependent to the hydraulic fluid temperature. The accumulator is what holds the pressure that is built up by the pump. Right now you are not building sufficient pressure. That is not an accumulator problem. That is either a dead/failing motor or that resister.
3. Do the live data readings again after you removed the 10k resistor.
Old Mon, Jun-03-2019, 01:28:51 PM   #29
SMG cog light
https://youtu.be/2YpgQ_vxzNk
How long does it take for your motor to come back on after the pressure decays and the motor have to prime again without shifting?
Old Mon, Jun-03-2019, 01:47:41 PM   #30
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
I actually responded to you in this thread about the SMG pressure drop and time. Post #29 down.
http://www.m3forum.net/m3forum/showthread.php?t=606540
Discussing HOWTO: SMG Accumulator Pressure Test in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
