Old Thu, Nov-07-2013, 07:04:42 PM   #1
SteveEvans
Reputation: 0 SteveEvans is on a distinguished road
United Kingdom
Default HOWTO: SMG Accumulator Pressure Test
If you're having issues with your SMG pump you have the option of replacing the accumulator independent of the whole pump assembly. Before taking this step you should test the accumulator. This guide explains how to do so.
Should you be considering refurbishing your SMG pump to replace the motor and/or temperature sensor, I would advise conducting this test before your pump dies as you'd not want to go to all that effort and then be reinstalling a bad accumulator.
Note that this isn't a tutorial in getting DIS/GT1 running. The following assumes you'd achieved that.
Having connected everything up and go DIS running, click the Diagnosis button. Note that in the screenshot below I didn't have an active connection to the car, so there is no corresponding signal strength. All other screenshots were taken during the test procedure itself.
Then select the Series, in this case the 3 Series.
Then select the Model series, E46 and click the green arrow in the bottom right hand corner of the screen.
You will probably see a voltage warning unless you connect a charger. Whilst I would recommend connecting a charger if coding the car, in this instance it is safe (at your own risk!) to proceed. Click OK.
You'll then be invited to perform a Quick Test. Click OK.
Steve
Continued below...
Jump to top SteveEvans is offline   Reply With Quote
Old Thu, Nov-07-2013, 07:06:01 PM   #2
SteveEvans
United Kingdom
Default Re: HOWTO: SMG Accumulator Pressure Test
DIS will then identify the modules in your car and display those in finds white on black rather than black on white as shown below. Click Quick test.
DIS will then read the error codes stored in each module. A pass is indicated by a '!', whilst a fail is indicated with a 'x'. In the image below it can be seen that I had some stored errors associated with my IHKA and LSZ.
You'll probably also see some prompts for additional information an example of which is shown below. Click OK.
Click the green arrow in the bottom right hand corner which will take you to the Diagnosis Symptom Selection screen. This lists all the issues stored related to the car. This shows quite a list here which I have chosen to show for illustration, but they're a consequence of the battery having had a loose connection a short while ago and had yet to be cleared. Click the green arrow in the bottom right hand corner.
This takes you to the Diagnosis Test schedule screen. Click on Function selection.
Steve
Continued below...
Old Thu, Nov-07-2013, 07:07:03 PM   #3
SteveEvans
United Kingdom
This will allow you to select the accumulator test service function. Select it as shown and then click Test schedule to take you back to the previous screen.
You'll now see this test listed under Own test schedule. Ensure it is selected and click on the green arrow in the bottom right hand corner of the screen.
The test then starts with an explanation of the likely symptom. Click on the green arrow in the bottom right hand corner of the screen.
You'll then probably get another voltage warning. Ignore it by clicking on the green arrow in the bottom right hand corner of the screen.
Conditions for the test are then listed. Ignition must be on and engine off. Click on the green arrow in the bottom right hand corner of the screen.
Steve
Continued below...
Old Thu, Nov-07-2013, 07:07:52 PM   #4
SteveEvans
United Kingdom
The test will then run.
Once complete it automatically displays the result as shown below. Click the green arrow in the bottom right corner of the screen to conclude the test.
The end of test message is then displayed. Click the green arrow in the bottom right corner of the screen to return to the Test schedule listing.
Steve
Old Thu, Nov-07-2013, 10:47:29 PM   #5
cntrvrsy
44
cntrvrsy's Avatar
United Nations
Good stuff
sig engineered by Fcukupayme
Jump to top cntrvrsy is offline   Reply With Quote
Old Thu, Nov-07-2013, 11:29:25 PM   #6
kokgo20
kokgo20's Avatar
This can be done on INPA iirc.
Build thread---------- INSTAGRAM ------------ROTREX REBUILD-------------Now offering custom digital gauges
2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - SDW monoball RTABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom air vent A/F & boost gauge - VEI custom air vent Water temp & oil pressure guage- Active Prima plus + TTFS tune - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s - 16" Spal fan
Old Fri, Nov-08-2013, 02:23:28 AM   #7
RedM3/4
Very nice Steve, thanks much!
ADS
06 SMG/ZCP - April 09, MCS 2WR (replaced Dinan over Konis/replaced OE), Supersrpint street section3, RAC RG63, homelink with off-delay, multifunction steering wheel buttons, RacingBrake Front kit.
Old Fri, Nov-08-2013, 07:16:52 PM   #8
SteveEvans
United Kingdom
You're welcome. There are virtually no guides to using DIS online, so I figured this might be helpful.
Steve
Old Sat, Nov-09-2013, 12:40:16 AM   #9
GRKM3
GRKM3's Avatar
Reputation: 0 GRKM3 is on a distinguished road
great write-up
SOLD2003 Steel Gray Metallic M3 - Imola Red Interior - SMGII - Premium - HK Sound - NAV - BT -Sirius
Mods :VFE Stage 2 SC, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe,TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R Brakes, OEM CSL Roof, VCSL D/S Carbon Trunk, diffuser and bumper, Armrest Delete, carbon mirror shells, OEM LED tail lights, BBS CH, Alcantara steering wheel, Armrest delete, Valentine V1, Laser Interceptor...
Current ride: 2015 F32 435i xDrive with PPK
Jump to top GRKM3 is offline   Reply With Quote
Old Sat, Nov-09-2013, 04:17:56 AM   #10
MarkOne
I plead the FiF
MarkOne's Avatar
Reputation: 0 MarkOne is on a distinguished road
Good stuff mate. Nice to see more diy stuff for us smg owners.
"I then just left that Ho in my rear view"- ///M3PhrEAk
SOLD
2005 Carbon Black on Black M3 Coupe w/ SMG
Current Mods: M3an One headers, OEM euro section 1, K&N drop in filter, OEM zcp brakes, ECS brake lines, ST coilovers, Linea Corse LM reps (19x8.5 +35, 19x10 +22), Khoalty license plate LEDs, Turner painted reflectors, Depo matte black kidney grills, Depo smoked corners, Depo smoked side markers, EAS cf 2x2 interior trim, BSW subwoofer
Jump to top MarkOne is offline   Reply With Quote
Discussing HOWTO: SMG Accumulator Pressure Test in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
