Old Sat, Jun-08-2019, 02:29:58 AM   #801
sapote
I think he didn't understand my point; I wasn't telling people to drive with the leaky seal -- major or minor, but rather to analyze if the leak had caused enough low oil and overheat. Again, the seal is about 1" higher than the oil level (in fact with all the constant mesh gears spinning around the oil level would be very low to pour out), so I think there is still much oil remained after just 10 miles drive.
Old Sun, Jun-09-2019, 03:36:43 AM   #802
HDdave
HDdave's Avatar
Reputation: 0 HDdave is on a distinguished road
Okay... So after pulling the trans again I did find the seal was very badly folded inside out.. Def would advise anyone thinking about doing this swap to make sure you install seal after the bellhousing is on!
I did wind up losing prly 1/2 to 2/3 or a liter driving mine those 10 miles. I do believe that is what led to the heat, and my (what I am now realizing are normal) trans noises being louder. I got the car back together today with the new seal and everything feels great! Used BMW MTF LT-2 for fluid instead of whatever it was I got from ECS the first time.
As far as me thinking it wasnt shifting right.. Well I am sure low fluid had a lot to do with that. It is a learning curve for sure. Seeing as the car has a new clutch and flywheel, and basically every single component in the drivetrain that seals anything or spins replaced... It just takes some getting used to. Also the only other thing I have to compare it to is the one other 6 speed m3 I have driven (which was completely beat/ worn out).
So- Overall I love it!! Very pleased with the whole project. Huge thanks to everyone in here who has helped!
******* Side thought****** Does anyone who has a bellhousing off know/ or would be capable of checking to see what size threads the two fitting screwing into the bellhousing are (the ones we connect nothing to when we put the swap back together). There is another forum member who makes custom air vent gauges. I think it would be awesome if I could get some kinda conversion fitting to remove one of those sensors, then adapt it to NPT so I could run a temp sensor. Thoughts on this, or does anyone know those sizes?
2003 TiAg 6mt/ Euro Headers/ OEM resonated sec 1/ Beisan VANOS/ Reinforced Subframe/ BC coils/ VMR 710ís/ PS4s Dynavin/ Bavsounds/ Coby Wheel/ AFE/ Angel Eye Guy/ VAC/ Mishimoto/ Morimoto fogs/ Turner CSL intake on order..
16 Denali HD Duramax Stone Blue Metallic- Toyo 35's
Jump to top HDdave is online now   Reply With Quote
Old Fri, Jun-21-2019, 02:27:33 PM   #803
Angelom3vert
Reputation: 0 Angelom3vert is on a distinguished road
Did the manual swap and my car started leaking . I thiught maybe i damaged the seal while putting the bell housing . I paid someone to redue the seal and it leaked again , he put the seal before attaching the bellhousing to transmission , do you guys install the seal after attaching bellhousing or before ? Pleasw help this is the second time we pulled tranny
Jump to top Angelom3vert is offline   Reply With Quote
Old Fri, Jun-21-2019, 05:47:06 PM   #804
Angelom3vert
Do u have the seal part number , want to make sure buy i get the wrong one
Old Fri, Jun-21-2019, 05:54:48 PM   #805
HDdave
HDdave's Avatar
Whoever you paid to do it needs to fix that- It is clearly not installed correctly
Old Fri, Jun-21-2019, 06:35:03 PM   #806
RedOctober330
RedOctober330's Avatar
Reputation: 0 RedOctober330 is on a distinguished road
Originally Posted by Angelom3vert View Post
Iíll go to Mexico.
Jump to top RedOctober330 is offline   Reply With Quote
Old Fri, Jun-21-2019, 06:40:49 PM   #807
sapote
Installed before or after doesn't matter as long as the seal lip was protected from damaging by the input shaft splines.
Old Sat, Jun-22-2019, 06:06:14 PM   #808
Angelom3vert
The seal was installed correcrly but pooped off
Old Fri, Jun-28-2019, 07:21:26 PM   #809
sw1
Reputation: 0 sw1 is on a distinguished road
Hey guys,
I finished my swap a day ago, and haven't had much time to test drive it, and don't even have it fully coded yet, but do have a couple of issues that need working out that I suspect are related to one another.
The car idles low when pulling into a parking spot or even at a light, it drops to about 500 and feels like it's going to stall even with the clutch in. Also above 2.5k I've noticed a new noise that sounds a bit like a whistle coming from around the intake.
My suspicion is that the hose at the bottom and towards the rear of the intake manifold wasn't reconnected correctly. I had a hard time getting it to seat nicely. Does anybody know if it's supposed to click into place, because I was not able to get it to click, and even seating it the best I could, it didn't seem all that secure.
Does anybody have a part number for that hose? I'd like to take a closer look at it before tearing out the whole airbox again. Where does it go/what does it do?
Thanks.
Jump to top sw1 is online now   Reply With Quote
Old Fri, Jun-28-2019, 07:25:18 PM   #810
bigo1087
Reputation: 0 bigo1087 is on a distinguished road
You may have missed, but the SMG DME software expects the clutch to be pushed in when idling ( I think this is reason) and you'll experience stalling occasionally. There is a difference in the file for the idle compared to the 6MT file.
Once you flash the 6MT DME File this will be corrected.
Sent from my Pixel 2 XL using Tapatalk
2006 IB ZCP| 6MT | H&R| SGT Scorza| TTFS | Turner | JVT| Dinan | AKG |
Jump to top bigo1087 is offline   Reply With Quote
