Old Wed, Jun-12-2019, 03:08:12 PM   #9971
sidepc
Reputation: 0 sidepc is on a distinguished road
Default Re: What did you do to/for your ///M today?
Removed the sun visor warning stickers for a cleaner look:
'05 Silbergrau Metallic 6MT
Jump to top sidepc is offline   Reply With Quote
Old Wed, Jun-12-2019, 03:10:28 PM   #9972
Will ZCPM3
Sparty On
Will ZCPM3's Avatar
Reputation: 0 Will ZCPM3 is on a distinguished road
What process did you use? Mine are partially falling off and I'd like to just remove them completely.
Instagram
Jump to top Will ZCPM3 is offline   Reply With Quote
Old Wed, Jun-12-2019, 03:13:11 PM   #9973
sidepc
Soak a paper towel or thick napkin in isopropyl (rubbing) alcohol. Then lay the wet paper towel (or whatever you use) on top of the stickers and let it sit for 15 to 20 minutes.
Then work at one corner and it should peel up relatively easily and you should be able to peel off the entire label in one shot. If the sticker isn’t coming off that easily yet, add more alcohol to the paper towel and lay it on the stickers a little bit longer. Shouldn’t take more than a half an hour.
Old Wed, Jun-12-2019, 03:14:15 PM   #9974
sidepc
Also I realize you can see the outline of where the stickers were, but that should fade in short time. Had the same issue on my E90 and after a few weeks, you could barely notice where the labels originally were adhered.
Old Fri, Jun-14-2019, 08:47:34 PM   #9975
Kaptom540
Reputation: 0 Kaptom540 is on a distinguished road
Did an oil change and replaced the oil cap
Jump to top Kaptom540 is offline   Reply With Quote
Old Fri, Jun-14-2019, 09:38:32 PM   #9976
csynic
Reputation: 0 csynic is on a distinguished road
hey i'm looking to replace the M tricolor sticker on the engine bay cover (just under the oil cap) - does anyone know where to find this sticker? tried searching on ebay but only the entire emblem shows up
Jump to top csynic is offline   Reply With Quote
Old Fri, Jun-14-2019, 09:48:14 PM   #9977
There is no sticker unless you can find an aftermarket solution. The badge is expensive and you can't just stick on a trunk badge, the one on the engine is larger. Suck it up or live with the faded/cracked/rippled one.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · zero options · ~3200lbs · JOURNAL
_
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 S pipes 2.5" + 200 cell HFC · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pullies · fan/SAP/washer delete · CSL battery
Bilstein HD B6/Eibach 325/600lb + GC "tall" RSMs · Hotchkis front sway (med) · rear strut bar · TMS camber & subframe plates · Eibach alu rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing · Mason clutch pedal + brass bushing · TMS black pedals · delrin brake pedal bushing
OE CSL trunk · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL · ZHP "712" rack · Pioneer/CDT/Eclipse/Kicker
Old Fri, Jun-14-2019, 09:50:57 PM   #9978
Good
@GOOD_M3
Good's Avatar
Use some wire, pry up the emblem, a bit of goo-off and you’ll have the surface clean ready for a fresh emblem. There is no easy way out
EXTERIORVÖRSTEINER CSL BUMPER | MILE END CSL 1X1 DIFFUSER & FLIPPERS
ENGINE ▌TUNED BY PAUL-CLAUDE | KARBONIUS CSL AIRBOX (ALPHA N), OE SNORKEL + CSL DUCTING | VANOS BEISAN LOCKDOWN: UPPER GUIDE CHAIN | SOLENOID COIL PACK | OIL PUMP DISK
TRANSMISSIONBURKHART SMG MOTOR, TEMPERATURE SENSOR, RELOCATED | '255' CSL SMG DME TUNE | INERTIA SMG DME UPDATE | WARM-UP LIGHT RECALIBRATION
SUSPENSIONTURNER MOTORSPORT 30MM FRONT SWAY BAR | KW V3 COILOVERS | SDW RTABS
EXHAUSTSUPERSPRINT EXHAUST ~ OVERSIZED STEPPED V1 HEADERS | RACE CATTED SEC 1 | STOCK2 | SPORT (GEN 2) SEC 3
BRAKES ▌CSL/ZCP ROTORS | PORSCHE 996 BREMBO CALIPERS | SS LINES
WHEELS ▌ZCP BBS 19" | 75MM ECS/TMS WHEEL STUDS
Instagram: https://www.instagram.com/good_m3/?hl=en
Youtube: https://www.youtube.com/channel/UCOW...3N7QDfZ5NSzriA
Journal: http://www.m3forum.net/m3forum/showthread.php?t=599036
Old Sat, Jun-15-2019, 01:50:02 AM   #9979
///M3_Michael
///M3_Michael's Avatar
Reputation: 0 ///M3_Michael is on a distinguished road
If the chrome M part is in good shape and all you need are the stripes then someone on here sells just those as a sticker. I have one in the garage somewhere from about 6 months ago. Bought but never used as I came across the entire emblem cheap.
2003 ///M3 6MT Slicktop | Phoenix Yellow | Black Nappa | Koni Yellow / Eibach Pro kit | GC Street Plates | 18" Apex ARC-8 | Fabspeed Headers | Fabspeed catted Section 1 | SGT Resonated Section 2 | RE El Diablo | buildjournal B-spec V2.1 tune | Infinity | JL Audio
Jump to top ///M3_Michael is offline   Reply With Quote
Old Sat, Jun-15-2019, 02:45:32 AM   #9980
TechieTechie
TechieTechie's Avatar
Reputation: 0 TechieTechie is on a distinguished road
Transfered her into my name. Love the M3 power with the wind in my hair. Must resolve hardtop squeeks, tho.
"Don't be fooled, she drives with the aggression of a scorned 17 year old"
Jump to top TechieTechie is offline   Reply With Quote
Discussing What did you do to/for your ///M today? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
