Old Thu, Aug-09-2018, 10:50:00 PM   #11
Edgy
Constantly Learning M3 and M5 Owner
Edgy's Avatar
Reputation: 0 Edgy is on a distinguished road
Default Re: DSC-Brake Warning Lights, Found one Fix
Subscribed - unfortunately. Got the double lights today, and the fluid is not low. In fact it was a little too high, so I'm going to drain a bit and see what happens. Have a DIY event this Sat, hopefully the shop can read codes.
BLUE HEAVEN:
Interlagos 2006 M3, AutoLogic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Conforti/Shark tune. MRegistry listing here
Jump to top Edgy is offline   Reply With Quote
Old Fri, Aug-10-2018, 12:06:12 AM   #12
stogybear
stogybear's Avatar
Reputation: 0 stogybear is on a distinguished road
Armenia
I had these lights come on about a month ago. Shut the car off and started it and they went away and have come on since then. Been wondering what the hell happened.
2005 AW M3 - 6MT - Bay Area
Jump to top stogybear is offline   Reply With Quote
Old Fri, Aug-10-2018, 01:37:40 AM   #13
Metro81
Reputation: 0 Metro81 is on a distinguished road
Originally Posted by LightWerkz View Post
Also this just disables your DSC, no reason why you couldn't go to the track
Disabling DSC and having multiple related lights illuminated due to an issue within the system are two very different things. Had the double lights, unfortunately at the end of the front straight at VIR, and found myself with almost no brake pressure and a nice jaunt through a field. Id say that OPs decision not to track was probably a safe one.
TTFS | CPI | RE | APEX | PFC | KW | GC | BimmerWorld | Hard Motorsports | Status Gruppe | n15DESIGN | RaceWerks
Jump to top Metro81 is offline   Reply With Quote
Old Fri, Aug-17-2018, 07:03:51 AM   #14
XpME46M3
Reputation: 0 XpME46M3 is on a distinguished road
This happened to me as well. I replaced both DSC pressure sensors (Master Brake Cylinder). I bought the cheap sensors off ebay for under $20 each and they did the job.
Jump to top XpME46M3 is offline   Reply With Quote
Old Fri, Sep-21-2018, 04:04:57 PM   #15
Edgy
Edgy's Avatar
Ebay sensors still working? Worried about going that route but these sensors are expensive. Will check with reader when lights come back on.
BLUE HEAVEN:
Old Fri, Sep-21-2018, 04:13:09 PM   #16
Hender107
Reputation: 0 Hender107 is on a distinguished road
To each is own, but from my experience its not a job you want to do twice. Paying a shop or pulling them out yourself. Buy OE sensors from fairfax BMW, replace them and they'll be good for another 10 years.
Jump to top Hender107 is offline   Reply With Quote
Old Mon, Sep-24-2018, 03:23:53 AM   #17
Elgm
Reputation: 0 Elgm is on a distinguished road
Norway
Originally Posted by VGLNTE1 View Post
I checked mine and the fluid was a little low, so I filled it just below the MAX mark...lights turned off. I drove the car, then shut it off. Turned it back on an hour later and they pop back up again. When these lights are on, the only thing I dont have is traction control right?
ABS is disabled too.
Jump to top Elgm is offline   Reply With Quote
Old Tue, Jun-11-2019, 07:24:43 PM   #18
Edgy
Edgy's Avatar
Anyone try this, disconnect the relay a few times? Seems like it can't hurt:
BLUE HEAVEN:
Discussing DSC-Brake Warning Lights, Found one Fix in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
