Old Tue, Jun-14-2016, 11:02:25 PM   #11
Chapelle
Chapelle's Avatar
Reputation: 0 Chapelle is on a distinguished road
Default Re: DSC Pressure Sensor replacement
Bump as well. Light comes on and goes off every day or two. My indy got both pressure 1 and 2 while car was running. Reset and pressure 2 was still at fault. Would love a DIY on this...
Edit: Found a small write up online: https://autotecdirect.wordpress.com/...r-replacement/
Can anyone confirm this is the best method for replacing the sensors and/or are there photos out there?
Jump to top Chapelle is offline   Reply With Quote
Old Tue, Aug-02-2016, 03:02:02 PM   #12
Chapelle
Chapelle's Avatar
Bump again. Can anyone verify the steps on the link I posted above? Still have my DSC and handbrake lights on, somewhat intermittently.
Also, when you bleed the brakes (before?) performing this job, is there anything out of the normal bleed job that you would worry about (i.e. master cylinder bleed)?
Thanks in advance.
Old Tue, Aug-02-2016, 03:51:05 PM   #13
Flow
Flow's Avatar
France
Here is the BMW instructions for replacement :
http://d.pr/f/1fnks
I hope that will be helpful
2004 M3 TiAg / LSB SMG
Old Tue, Aug-02-2016, 07:09:36 PM   #14
Chapelle
Chapelle's Avatar
http://d.pr/f/1fnks
Thanks, Florian!
Old Tue, Nov-29-2016, 04:38:19 PM   #15
Chapelle
Chapelle's Avatar
Finally got my sensors and I figured this was a good time to replace them as I was going to bleed my brakes for winter storage anyway.
Has anyone attempted this recently? Is it better to flush the brake fluid BEFORE or AFTER the replacement?
As long as I have the brake fluid reservoir full prior to removing the sensor, I should have enough in there where I won't bleed it dry in the time it takes to swap the new one in, right?
**EDIT** I didn't realize you need to take the reservoir off prior to removing the sensors. Can you switch the sensors over fast enough so all you have to do after the procedure is bleed the brakes as normal (IE no special ABS "pulsing" via equipment)?
Any other tips on this job would be helpful, since there isn't a lot of information online. Florian's diagrams (posted above) help a little bit, but there is still some uncertainty.
Old Thu, Apr-19-2018, 03:46:32 PM   #16
LemonOne
LemonOne's Avatar
Reputation: 0 LemonOne is on a distinguished road
Was anyone successful after replacing the DSC sensor? Any update on this "issue solved"?
2006 Imola Red / Cinnamon SMG II
Jump to top LemonOne is offline   Reply With Quote
Old Tue, Jun-11-2019, 07:17:03 PM   #17
Edgy
Constantly Learning M3 and M5 Owner
Edgy's Avatar
Reputation: 0 Edgy is on a distinguished road
Subscribed for reference
BLUE HEAVEN:
Interlagos 2006 M3, AutoLogic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Conforti/Shark tune. MRegistry listing here
Jump to top Edgy is offline   Reply With Quote
dsc, pressure, replacement, sensor
Discussing DSC Pressure Sensor replacement in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
