Old Tue, Jun-09-2009, 02:02:48 PM   #1
sosheal
sosheal's Avatar
Reputation: 0 sosheal is on a distinguished road
Default DSC Pressure Sensor replacement
Like several others, I'm experiencing an intermittent yellow BRAKE light and DSC light (no ABS light) malfunction. Codes repeatedly are 5e16 (CAN instrument timeout) and 5e20 (DSC pressure sensor 1, electrical failure). So, I figure replacement of the sensor is in order.
For those who have replaced this sensor or done work on the master cylinder, is this a job for a moderately competent DIYer? Once the plastic partition that separates the area of the master cylinder from the engine bay is removed, is there room to get to the sensor and remove it (car is 6MT)? Does the brake fluid reservoir need to be emptied prior to removal of the sensor? Does the hydraulic system need to be bled after the sensor is replaced? Is sensor 1 the front one on the master cylinder? Any hints, tips, or experience to share? Anything that should be done before replacing the sensor?
Thanks.
Jump to top sosheal is offline   Reply With Quote
Old Sat, Jul-11-2009, 03:00:18 PM   #2
BMWGuy206
Reputation: 0 BMWGuy206 is on a distinguished road
Any luck with this? Did replacing the pressure sensor get rid of the problem?
Jump to top BMWGuy206 is offline   Reply With Quote
Old Wed, Jan-26-2011, 08:15:23 AM   #3
MartyM3
Reputation: 0 MartyM3 is on a distinguished road
New Zealand
Default Re: DSC Pressure Sensor replacement
Sosheal......do you have an update on this?
I got a DSC light today and GT1 (on VM laptop) indicated DSC pressure sensor 2.
Would be nice to be able to fix it myself....with some advice?
Marty
Jump to top MartyM3 is offline   Reply With Quote
Old Sat, Dec-28-2013, 05:55:02 AM   #4
///M_Achilles
"Visor down for business"
///M_Achilles's Avatar
Reputation: 0 ///M_Achilles is on a distinguished road
Any tips? Would it be easier to remove the DME or remove the brake fluid reservoir to access the BPS/DSC sensor. TIA
2005 Carbon Black Metallic ///M3 SOLD
My Journal
2012 Porsche Cayman R
Jump to top ///M_Achilles is offline   Reply With Quote
Old Sat, Dec-28-2013, 12:38:02 PM   #5
p0lar
Naturally Agitated
p0lar's Avatar
Pressure Sensor #1 is for the front (V or Vor) hydraulic circuit, and should be marked with a '25' next to it (in both MK60 and non-MK60 vehicles). Pressure Sensors #2 is for the rear (H or Hinter) hydraulic circuit and should be marked with a '20' next to it on the older non-MK60 vehicles (<09/2002) and a '22' next to it for MK60-equipped vehicles.
You will most certainly need to bleed your brakes thereafter. In theory, you could just bleed one leg of one hydraulic circuit, but you'll also have to do an ABS bleed since you'll be forcing any potential bubble all the way through it as well. That being said, I wouldn't take the chance, just bleed the whole thing and be sure it's done right.
I've seen it done another way where bleeding wasn't required, but I'm not going to detail it as it was a total hack and I found myself surprised it worked as well as it did.
Old Sat, Dec-28-2013, 01:28:20 PM   #6
///M_Achilles
Thanks for the advice. I'll for sure bleed the whole hydraulic system: brakes and clutch. I was just inquiring for tips accessing these DSC sensors. Just a quick glance, it looks buried in there like an Alabama tick. I believe I found a solution, however. Thanks again
Sent from MI6
My Journal
Old Sat, Dec-28-2013, 06:11:27 PM   #7
audipwr1
Reputation: 0 audipwr1 is on a distinguished road
You will want an open ended wrench for the sensor, fluid will come out when you take sensor out so make sure to have lots of shop towels shoved down in the compartment.
100% have to bleed system post doing this and run the abs sensor flush as well or it'll cause you problems
Took me 3 or so hours to do, all of it was prep work to make sure brake fluid didn't bit anything and that was worth doing
Jump to top audipwr1 is offline   Reply With Quote
Old Mon, May-12-2014, 06:14:34 PM   #8
Cuz5150
Cuz5150
Cuz5150's Avatar
Reputation: 0 Cuz5150 is on a distinguished road
Trouble in paradise!!!
I found this thread via searching and i'm bring it back.
My 04 Vert has been experiencing this a few times. The lights have come and gone. However, its back and its been ON for the past 3 days.
I stopped at a local indy and got the same codes as the OP.
Any DIY or pics? Also whats the cost at the dealership?
Im Bump out about this, I hate lights on my instrument cluster/
Should i start by cleaning out the abs wheel sensors first? The car has 26K on the clock, garaged kept and brake fluid flushed every 2 yrs.
Thanks
http://im1.shutterfly.com/media/47a3cc29b3127ccef48539c87df200000030O00AaNHDJi0YuG  IPbz4a/cC/f%3D0/ls%3D00108141284420131209001350520.JPG/ps%3D50/r%3D0/rx%3D550/ry%3D400/
2007 Z4 Coupe/Black/Black/6mt/Premium/Xenon
2004/M3/Vert/Black/Imola/6mt/Cold/Xenon/HK
2006/M3/Coupe/Mystic/Black/6mt/ZCP/Xenon/HK
2009/135i/Coupe/Alpine/Black/6mt/M-sport/Idrive-sold
2002 998 Ducati-sold
-Diplomacy is saying "nice doggie" while trying to find a rock
Jump to top Cuz5150 is offline   Reply With Quote
Old Mon, May-12-2014, 10:36:41 PM   #9
Cuz5150
Cuz5150
Cuz5150's Avatar
asking for some help....
Old Fri, Mar-25-2016, 07:24:48 PM   #10
The Hunter
Reputation: 0 The Hunter is on a distinguished road
I am also having this issue, so reviving this thread. Does anyone have advice?
Jump to top The Hunter is offline   Reply With Quote
dsc, pressure, replacement, sensor
Discussing DSC Pressure Sensor replacement in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
