Old Tue, Feb-12-2019, 06:14:42 PM   #981
brichter
Unregistered Abuser
brichter's Avatar
Reputation: 0 brichter is on a distinguished road
Default Re: SMG troubleshooting FAQ
So you think it was easier reading the 30 pages of stuff on the internet, than to perform a basic visual inspection of the system and locate the problem?
2002 AW M3
Jump to top brichter is online now   Reply With Quote
Old Wed, Feb-13-2019, 01:29:20 PM   #982
IggyP
Reputation: 0 IggyP is on a distinguished road
To see all possible things that could break. Its my first m3, my first "automatic" car and I'm obviously not as good of a mechanics or internet troll like you are.
I've heard some bad things about m3 forums and here's my first taste. Good day
Jump to top IggyP is offline   Reply With Quote
Old Tue, Mar-05-2019, 01:25:13 AM   #983
oceansize
Kwisatz Haderach
oceansize's Avatar
Taken from ISTA+ SMG Notes
When Replacing SMG control unit:
1. Teach in clutch valve characteristic values
2. Adapt complete transmission
3. Teach in clutch slipping point
4. Teach in offset of longitudinal-acceleration sensor
After working on the hydraulic system, if the system was opened:
1. Bleed actuator block
2. Bleed clutch slave cylinder and hydraulic lines
After removal and reinstallation of parts (no replacement of parts!)
When replacing transmission
When replacing hydraulic unit with actuator block
When replacing engine
3. Teach in clutch valve characteristic values
4. Adapt complete transmission
5. Teach in clutch slipping point
When replacing clutch
Note: Perform point 1 only if the hydraulic system was opened.
1. Bleed clutch slave cylinder and hydraulic lines
2. Teach in clutch valve characteristic values
4. Reset clutch curve (automatically carried out by BMW diagnosis system after successful teaching in of points 3 and 4)
When replacing individual clutch parts:
- Release lever
- Ball pin
- Release bearing ...
2. Teach in clutch slipping point
3. Reset clutch curve (automatically carried out by BMW diagnosis system after successful teaching in of points 1 and 2)
When replacing clutch slave cylinder with PLCD sensor
4. Teach in clutch slipping point
5. Reset clutch curve (automatically carried out by BMW diagnosis system after successful teaching in of points 3 and 4)
When replacing longitudinal-acceleration sensor
1. Teach in offset of longitudinal-acceleration sensor
2003 M3 Convertible SMG w/Hardtop | GC Coilovers and Camber Plates | ESS VT1-475 Gen 3 Supercharger | Stoptech Brakes
Apex ARC-8 19" Hypersilver | CSL SMG (and 255) Tune | RE Diablo Exhaust w/ SS Tips | RE Rasp Pipe
Storm Motorwerks SMG Paddles | Two Tone Black/Grey Interior | Alcantara E-brake Boot
Very Recent Maintenance: FCABs | FCAs | RTABs | Motor Mounts | PS Hoses | Inner/Outer Tie Rods | End Links | Vanos Solenoid |
Driveshaft R&R | Flex Disc | Fan Clutch | Trans Fluid | Diff fluid
Old Mon, Mar-25-2019, 10:37:42 PM   #984
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Easily the best thing I've done with my SMG thus far...
Should have done this YEARS ago.
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized HJS Race Catted section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Brembo GT6 (front) + GT4 (rear) BBK, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, SMG Pump Relocated.
Camshaft Group-Buy, OE CSL Bootlids, Supersprint Headers/Exhaust thread, New Supersprint Oversized Twin-Piped Section 2
Old Mon, Jul-01-2019, 03:00:23 AM   #985
GG///M3
LOUNGE CREATOR
GG///M3's Avatar
Reputation: 0 GG///M3 is on a distinguished road
Albania
Iím a newb. What was done ?
Jump to top GG///M3 is online now   Reply With Quote
Old Tue, Jul-02-2019, 01:42:07 PM   #986
jdamore44
jdamore44's Avatar
Reputation: 0 jdamore44 is on a distinguished road
SMG Unit Relocation to former ABS compartment aka "drug bin"
1983 320iS - SOLD
1997 328iS Sport - SOLD
2003 Steel Grey Metallic M3 6MT Coupe, Black Interior
Jump to top jdamore44 is online now   Reply With Quote
Old Tue, Jul-02-2019, 08:54:57 PM   #987
GG///M3
LOUNGE CREATOR
GG///M3's Avatar
Albania
Any idea what kind of pricing for this kit ?
faq, smg, troubleshooting
Troubleshooting Codes AirDoc E36 M3 (1992-1999) 0 Sat, Nov-17-2007 03:49:53 AM
Troubleshooting a problem ----> HELP ! RoadShreader E36 M3 (1992-1999) 43 Sun, Dec-31-2006 07:05:57 PM
Eclipse Troubleshooting crazy32184 E36 M3 (1992-1999) 7 Thu, Jun-09-2005 07:03:15 AM
HELP PLEASE!!! Troubleshooting my ///M! M3nEwBoOtY E36 M3 (1992-1999) 6 Sun, Apr-03-2005 04:37:52 PM
Discussing SMG troubleshooting FAQ in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
