Old Sun, Nov-04-2018, 02:10:59 PM   #1221
rwfisher
Reputation: 0 rwfisher is on a distinguished road
Default Re: e46 M3 Maintenance Thread
Silly question of the day...what's the nominal lifespan of the rear springs for a street-only vehicle? I believe i read that the shocks and struts are affected by lowering, but is this the case for springs as well?
Jump to top rwfisher is offline   Reply With Quote
Old Sun, Dec-09-2018, 06:50:26 AM   #1222
fayraree
fayraree's Avatar
Reputation: 0 fayraree is on a distinguished road
Originally Posted by rwtw0165 View Post
Much appreciated! I'm due for a valve adjustment and I am no way going back there... They couldn't even change my corner bulb for me without breaking my headlight tab!
Saw this too late! You need to go to Total M Car (fellow member owns it: Coinage) in Annville, PA. Hands down one of the best S54 Indy mechanics on the east coast. You should look through my maintenance thread:
http://www.m3forum.net/m3forum/showthread.php?t=451183
The man is a genius. Have your VANOS thoroughly inspected when you do a valve adjustment.
It's true what they say about verts...
Jump to top fayraree is offline   Reply With Quote
Old Tue, Dec-25-2018, 11:26:53 PM   #1223
ATB88
Reputation: 0 ATB88 is on a distinguished road
Maintenance question: now that these cars are getting pretty old has anyone done any cleaning/lubrication of the ITB throttle linkages? Would this ever be necessary/beneficial for smoother throttle actuation? It wouldn't be absurd to me if the springs that provide resistance to the opening of the ITBs could use a little grease since mine have kind of rough looking surface metal which could be causing friction as the ITBs open. Also maybe the little ball joints on either end of each plastic linkage piece? Is this a ridiculous thought?
If anyone has done this, do you have a recommended lubricant that would work well for this purpose and also not attract grime that would make things worse down the road?
Jump to top ATB88 is offline   Reply With Quote
Old Wed, Dec-26-2018, 12:52:21 AM   #1224
BearDeXPS
BearDeXPS's Avatar
My springs and linkage were thoroughly cleaned and greased when they were removed.
A better question imo is when will we see the springs needing to be replaced? Some are coming up on 20yrs..........
We lightly used a white lithium grease. But I dont daily my car so grime doesn't build up at all.
Old Wed, Jan-02-2019, 04:06:42 PM   #1225
Denteen
Newbie
Reputation: 0 Denteen is on a distinguished road
Fantastic thread. Not a mechanic but love working on my cars at the lower levels
Jump to top Denteen is offline   Reply With Quote
Old Wed, Jan-02-2019, 04:07:47 PM   #1226
Denteen
Newbie
Interested in the Q on springs as well. Honestly, at 83k miles my 04 feels good but Im sure the bushings are tired
Old Wed, Jan-02-2019, 04:10:19 PM   #1227
Denteen
Newbie
Originally Posted by Elgm View Post
Recently found and replaced this on an m3. I would like to remind you to check the fittings on your oil cooler lines at least yearly. Car had 170k kms.
Excellent. Thanks for sharing this.
Old Thu, Jan-10-2019, 03:02:49 PM   #1228
jdauria
Reputation: 0 jdauria is on a distinguished road
Putting parts listing together for diff seal service. Had the vehicle up in the air the other day and noticed a fairly significant leak around the differential.
33121213949 OEM Front Seal (Diff)
33111214144 OEM O-ring (x2)
83222282583 OEM Diff Oil (x3)
33107510289 OEM Shaft Seal with lock ring (x2)
33121205138 OEM Drive Flange Washer
Am I missing anything?
National Capital Chapter #465420 ///M Registry
2009 ///M3 | Interlagos Blue | Silver Novillo | Sycamore Anthracite trim | DINAN DCT
2006 X5 4.8iS | LeMans Blue Metallic | Creme Beige | SOLD
2002 ///M3 | Steel Gray Metallic | Imola Red | 6MT | Convertible | Eibach | SOLD
2006 ///M3 | Silver Gray | Black | Competition Package (ZCP) | 6MT | SOLD
2000 ///M5 | Oxford Green Metallic II | Caramel Nappa Leather | BMW Individual Black Birch Trim | SOLD
2003 X5 4.6iS | Black Saphhire Metallic | Black Sport | SOLD
2006 X3 3.0i M-Sport | Silver Gray | Terracotta | SOLD
Jump to top jdauria is offline   Reply With Quote
Old Sun, Mar-10-2019, 10:54:29 PM   #1229
ATB88
Front struts: Didn't see any specific info about this on the main post. My car has 63k miles. Is it basically guaranteed that the front struts are shot at this point? Or does it really depend on how the car has been driven? Suspension is 100% factory stock except fresh Koni yellow shocks in the rear.
From looking around it sounds like 60k is about their service life, but if mine happen to still be healthy I would prefer to delay the inevitable. What's the best way to diagnose this? Would degraded struts cause poor tire wear (like cupping, which worn shocks can cause in the rear)?
Old Wed, Aug-07-2019, 06:28:14 PM   #1230
tegraphile
tegraphile's Avatar
Reputation: 0 tegraphile is on a distinguished road
Really detailed and informative. Thank you!
2014 335i M-sport . 2014 Acura RDX
Jump to top tegraphile is offline   Reply With Quote
e46, getbmwparts.com, maintenance, thread, tischer
:: ECS Tuning :: Selection of E46 M3 Maintenance Products and Service Kits ECSTuning M3Forum Sponsor Announcements and Specials 1 Wed, Sep-24-2008 05:21:18 PM
E46 maintenance / DIY support ? jav1 E46 M3 (2001-2006) 19 Tue, Aug-21-2007 04:29:00 AM
FS: 2002 E46 M3 (SMG) - CPO/Extended Maintenance (BMW Individual) NoSoup4U Parts for Sale/Wanted 6 Thu, Jun-29-2006 08:14:08 PM
The Preventative Maintenance Thread Obioban E46 M3 (2001-2006) 1 Tue, Jul-05-2005 10:38:25 PM
E36 M3 vs. E46 328Ci -- Maintenance Costs gdhyde E36 M3 (1992-1999) 13 Sat, Dec-11-2004 06:23:39 PM
Discussing e46 M3 Maintenance Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
