Old Mon, Jun-10-2019, 07:24:07 PM   #201
Default Re: Chach's DIY Porsche 996 BBK Conversion extensive write up
Keep in mind people, you don't just want clearance, you want a fair amount of clearance. If the gap is less than about 5mm, you'll get little rocks and debris getting stuck in there, ruining the finish of the calipers.
Also, with little or no gap, the calipers are more hidden/blocked, aesthetically. Moving the wheel out a bit more looks better.
/// 2004 SilberGrau M3 Coupe 6MT slicktop zero options ~3100lbs JOURNAL
Evolve-R Alpha N Evolve CF CSL Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 2.5" sect 1 OE sect 2 SCZA 2.5" sect 3 Besian RE pulleys/fan delete CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs Hotchkis front sway F & R strut bars TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB OE weighted ///M knob + ZHP alcantara boot + UUC DSSR
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 345mm CSL + Textar & 328mm CSL + ATE ZHP "712" rack
DD: 2012 TiAg/Blk 128i N52 ULEV Slicktop 6MT manual heated seats
Eibach springs & sways Koni STR.T Whiteline SF bushes Dinan camber plates M3 FCAs
Old Mon, Jun-10-2019, 10:16:09 PM   #202
SYRARCH04
Schmuck
Reputation: 0 SYRARCH04 is on a distinguished road
What are people running in these calipers for track pads? I was hoping to find something at FCP (for the replacement policy) like a Hawk HT10, but they don’t have much for these brakes it seems.
Jump to top SYRARCH04 is offline   Reply With Quote
Old Mon, Jun-10-2019, 11:04:41 PM   #203
zivagolee
@zivagolee
Reputation: 0 zivagolee is on a distinguished road
Originally Posted by SYRARCH04 View Post
What are people running in these calipers for track pads? I was hoping to find something at FCP (for the replacement policy) like a Hawk HT10, but they donít have much for these brakes it seems.
I'm using DTC-60s all around and so far feels pretty good. Nice initial bite and don't feel a lot of fade. FCP has these too for our sizes!
2003 Orient Blue M3
https://www.instagram.com/zivagolee
Jump to top zivagolee is offline   Reply With Quote
Old Sat, Jun-29-2019, 12:43:51 AM   #204
Engrmikl
Reputation: 0 Engrmikl is on a distinguished road
Hi all
Well finally got my calipers. EBAY set with 65k miles $450. Not perfect but with a rebuild and paint they should be good.
Questions for you all.
Who is running the shim/dampeners and why either way?
I am going to be doing a complete rebuild to include pistons. Anyone know the best place source these complete kits?
Also looking for the piston springs to help with the push back. Not sure if these are needed but if they are cheap I will use them.
Car will see the track several times a year so going to get it all done at once.
Haven’t decided on the front size yet. What’s the verdict on the CM adapters? Is there still a fitment issue on these or just the machine work and lop off a bit of the bracket and off you go?
Thanks
Jump to top Engrmikl is offline   Reply With Quote
Old Sat, Jun-29-2019, 01:46:07 AM   #205
duracellttu
I think fast, I talk fast and I drive fast...
Reputation: 0 duracellttu is on a distinguished road
Originally Posted by Engrmikl View Post
Hi all
Havenít decided on the front size yet. Whatís the verdict on the CM adapters? Is there still a fitment issue on these or just the machine work and lop off a bit of the bracket and off you go?
Thanks
Nice man! Iím in the process of rebuilding mine at the moment. I did a complete rebuild as well and purchased the shims. Iíve hear it just helps reduce the pad from rattling in the caliper. Not required but will help reduce weird noises. If itís a dedicated track car you might not care about that.
If you sourced your brackets from Rally Road then you should be good. When I spoke with them the told me they redesigned their bracket to have full coverage of the OE ZCP rotors.
2005 BMW M3 ZCP - Black/Black 2M Autowerks Full Restoration: RKP CF Roof Conversion, OE CSL Trunk, JCSL Diffuser
Paul Claudes Custom Tune | Kassel Performance CSL ECU Conversion+MAP Sensor | Lang Stage Stage 2.5 Head | 288/280 Schrick Cams+DLC Coated Followers | CSL Karbonious Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91 w/ 3 stage clutch
TCK SA 450/500 | Vorshlag Camber Plates | Rogue Engineering ASP, RSM | AKG FCABs, RTABs, SFBs | TMS Sway Bars, Camber Arms, Pullies | Mason Race Strut, Rear X-Brace | AS 30% SSK | SPAL Fan | Redish Reinforcement | Turbo Toys V2 Hub | WPC Treated Rod Bearings
Jump to top duracellttu is offline   Reply With Quote
Old Sat, Jun-29-2019, 02:53:36 AM   #206
Engrmikl
Where did you buy your rebuild kits and did they include pistons?
Haven't decided on brackets yet, might stick with the smaller fronts to use the lighter Euro rotors or non drilled so might need to go with the CMs from ECS. Also a less expensive in the long run.
On the shims then using the piston springs might do the same. I think Tbone or someone said they also can cause issues when making pad changes. Would have back track and read his statement again.
Old Sun, Jun-30-2019, 10:13:45 PM   #207
duracellttu
I didn't really purchase a "kit" per say. I found all of the part numbers and I sourced them all individually. I didn't feel the need to replace the pistons, just all the rubber and other hardware. I felt more comfortable purchasing OE Brembo seals versus Stoptech. It was really just personal preference, as many members have used the high temp Stoptech seals without issue. Below is where I sourced my parts and part numbers. Hope this helps!
- OE Brembo seals, bleeder screws, bleeder screw caps --> Hoerr Racing
- OE Porsche hydraulic connecting lines, brake kit hardware kit --> Pelican Parts
- Brake pad shims and textar pads --> FCP Euro
Front Caliper, Dust Boot (36mm): Brembo Part #BRE-20.4872.44
Front Caliper, Dust Boot (40mm): Brembo Part #BRE-20.4872.46
Rear Caliper, Dust Boot (28mm): Brembo Part #BRE-20.4872.40
Rear Caliper, Dust Boot (30mm): Brembo Part #BRE-20.4872.41
Front Caliper, Piston Seal (36mm): Brembo Part #BRE-10.55955.56
Front Caliper, Piston Seal (40mm): Brembo Part #BRE-10.55955.58
Rear Caliper, Piston Seal (28mm): Brembo Part #BRE-10.55955.52
Rear Caliper, Piston Seal (30mm): Brembo Part #BRE-10.55955.53
Brake Bleeder Screw : Brembo Part #BRE-02.2812.13
Brake Bleeder Screw Cap: Brembo Part #BRE-05.1502.20
Front Caliper, (Left) Hydraulic Connecting Line: OE Porsche Part #996-351-961-00
Front Caliper, (Right) Hydraulic Connecting Line: OE Porsche Part #996-351-962-00
Rear Caliper, (Left) Hydraulic Connecting Line: OE Porsche Part #996-352-961-00
Rear Caliper, (Right) Hydraulic Connecting Line: OE Porsche Part #996-352-962-00
Brake Hardware Kit (Front): OE Porsche Part #996-351-959-01
Brake Hardware Kit (Rear): OE Porsche Part #996-352-959-01
Brake Pad Shims (Front): OEM Part #996-351-088-02
Brake Pad Shims (Rear, 28mm): OEM Part #996-352-086-02
Brake Pad Shims (Rear, 30mm): OEM Part #996-352-086-00
Front Brake Pads (D917): OEM Textar Part #996-352-949-03
Rear Brake Pads (D737): OEM Textar Part #986-351-939-15
Old Wed, Aug-07-2019, 02:29:59 AM   #208
obious
Reputation: 0 obious is on a distinguished road
I don't know if this will save anyone, but stay the hell away from the adapters from Creations Motorsport. They are complete garbage. The rear adapters required clearancing from the upper control arm knuckle's bolt, and the front adapter's mount pins stripped at 40 ft lb when tightning the nut. Keep in mind that the OEM torque for the front calipers on the 996 is 63 ft lb! I was planning to tighten the nuts in stages.
[IMG width="600"]https://imgur.com/SjP52xV.jpg[/IMG]
[IMG width="600"]https://imgur.com/tFIiJUA.jpg[/IMG]
[IMG width="600"]https://imgur.com/p1jbW3Y.jpg[/IMG]
These things are outright dangerous.
Jump to top obious is offline   Reply With Quote
Old Wed, Aug-07-2019, 03:17:15 AM   #209
I had no such issues with 3 sets back to back to back. Drama queen much lol. Your pics don't show anything other than you cross threaded the nut
Old Wed, Aug-07-2019, 03:28:58 AM   #210
02_LSB
Reputation: 0 02_LSB is on a distinguished road
Same here. I assume these are the ECS tuning brackets.
LSB/Black | 6MT.
Brembo, TC Kline Double Adjustable, Full Supersprint, Beisan, Rod bearings, FX400 Single Mass Kit, AC Schnitzer, RACP plates + Bar + Too much Polyurethane.
SGM/Black E61 | 6MT
Stock
Jump to top 02_LSB is offline   Reply With Quote
Discussing Chach's DIY Porsche 996 BBK Conversion extensive write up in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
