E46 M3 (2001-2006) Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm Total Produced: 45,000+ - Years Produced: 2001 to 2006. |
Got a new full set of tires (after 18000), same ones that I had stock (Continental 19s). Now my tire pressure warning sensor is constantly on.
Pressures are identical all the way around (~40PSI), and I've reset the sensor numerous times (holding down until light goes out). A few miles later, it just comes back on. What's the deal? Has anyone else experienced this? (Getting kinda tired of this cheap-o flaky rotation-measurement sensor.) Thanks in advance |
Sponsored Links |
Did you reset it? search the forum for instructions.
![]() Location: SF Bay Area
Doesn't sound like you are performing the reset properly.
I believe you want to start with TPS light off, and then turn off the engine. turn the key to position 2. Press and hold the TPS button until it lights up (yellow). Then start the car, the light will go out after a couple of seconds. The steps are detailed in the manual as well. Juan
'03 M3 Cab, Steel Gray, SMG, NAV, HK, Alum Trim, Cold Weather Mods: SPP Fogs, Philips SilverVisions, V1 Hardwired, PhatBox 40Gb, Borla Exhaust OEM 19" with Toyo T1-S (245/35f and 275/30r) |
#4 |
![]() Location: H-town, Texas
Turn your ignition to pos 2 with the engine off. Hold the tire monitor button down until the light comes on. Let off of the button and wait until the light goes back off.
Bookmarks |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Tire Pressure Sensor - After new tires | neuralracing | E46 M3 (2001-2006) | 6 | Sat, Dec-01-2007 01:29:43 AM |
Tire Pressure Monitor - How does it work? - Sensor in the tire? | 04E46conv | E46 M3 (2001-2006) | 8 | Sat, Oct-13-2007 03:14:04 PM |
Wad tire pressure do u set for Stock 18 inch tires? | M3_Jetblack | E46 M3 (2001-2006) | 6 | Mon, May-14-2007 08:21:51 PM |
faulty tire pressure gauge it seems | smokiejjj | Faults, Fixes and DIY | 3 | Fri, Aug-04-2006 10:54:51 PM |
Tire Pressure Sensor | EMMME | E46 M3 (2001-2006) | 3 | Thu, Apr-10-2003 06:44:30 AM |
