Old Fri, Oct-12-2007, 07:34:30 PM   #1
04E46conv
04E46conv's Avatar
Reputation: 0 04E46conv is on a distinguished road
Default Tire Pressure Monitor - How does it work? - Sensor in the tire?
Anyone know where the sensor are located? and how they work?
Thanks!
2004 /// M3 Convertible
Factory: Nav | Xenon | HK Sound System
Mods: Euro Programing For Remote Top ( Up & Down ) | Hard Wired V1 | Hoen Fog's | Painted Reflectors | DICE HD Tuner W/ IPOD Cable | Dinan Short Shifter
Jump to top 04E46conv is offline   Reply With Quote
Old Fri, Oct-12-2007, 07:37:37 PM   #2
muncher
Reputation: 0 muncher is on a distinguished road
FTM stands for the Flat Tire Monitor. As air leaks, tire pressure decreases, and the tire rotates faster. ABS sensors on the wheels detect a change in wheel rotation speeds, which signifies a change in the roll radius, or pressure level, of the tires. A warning light in the instrument panel notifies the driver of the pressure loss. In case of significant pressure loss, a warning buzzer sounds.
TPM - Tire Pressure Monitor. Basically a two piece item, a special air valve as well as a module that is on the inside of the rim and connects to the valve stem. This unit monitors the actual pressure inside the rim. (This was introduced in the 2007 model year)
Copied from a post on bimmerfest by genearch
// 2001 Carbon Black M3 - ACS Springs - ACS short shifter - 19" Breyton Visions
Jump to top muncher is offline   Reply With Quote
Old Fri, Oct-12-2007, 07:40:15 PM   #3
04E46conv
04E46conv's Avatar
Thanks...just what I was looking for because I just herd some have that pressure monitor in the wheel and I wanted to make sure to let the guys at the shop know that need to be replaced when I get new tires..
Thanks again!
Old Fri, Oct-12-2007, 10:58:39 PM   #4
herkdriver007
you want WHAT delivered WHERE?
herkdriver007's Avatar
Reputation: 0 herkdriver007 has a spectacular aura about
our car uses the ABS to sense different rolling circumferences (RPM), thus telling you that you potentially have a tire going flat...
when you change your wheels and tires, just reset the sucker and go on about your business...
DOUG aka BUCHO
From the Factory: 2004 Titanium Silver/Imola Red 6MT
Mods: RAC RG4s wrapped in 245/275 Potenza RE760s, OEM CSL Bootlid, VCSL CF Diffuser,
ZCP front/rear drilled rotors, CF Kidney Grilles & Fender Gills, painted reflectors & fog light rings
TurboToy C300 Exhaust Hub
Official M3 Boobies Club: Boob #13
Jump to top herkdriver007 is offline   Reply With Quote
Old Fri, Oct-12-2007, 11:31:37 PM   #5
04E46conv
04E46conv's Avatar
Late time I every talk about the the Tire Pressure Monitor just got back from a 4 hour trip to the grocery store!!
On my way back the dash started beeping and that red Tire symbol lit up ...flat front tire!!
Old Fri, Oct-12-2007, 11:37:34 PM   #6
flproject13
flproject13's Avatar
Reputation: 0 flproject13 is on a distinguished road
Italy
mine always go off and I check tire pressure and it's fine. Personally I think the older TPM set up's in E46's were rushed to get into compliance with federal law under Clinton's TREAD Act. Actually as of September 1, 2007 all new cars MUST have some sort of tire pressure monitoring system. It never works right in comparison with our 545i. When that thing says you have a flat tire or low tire pressure, it's dead on.
2003 6MT///M3 Steel Gray
Jump to top flproject13 is offline   Reply With Quote
Old Sat, Oct-13-2007, 03:09:57 AM   #7
04E46conv
04E46conv's Avatar
I would say mine worked pefect.... I was driving down the highway the light went on and by the time I pulled over the tire was flat...
Old Sat, Oct-13-2007, 03:32:10 AM   #8
tdc
still notorious
tdc's Avatar
Reputation: 0 tdc will become famous soon enough
The E46 doesn't have a TPM, it has a FTM. Look at the above posts to learn the differences between the two.
stockWERKZ
M3BC #57
"Time cannot be influenced by mankind. It gives each of us a beginning and an end.
And this makes us question the significance of what comes between. But if you can
create something time cannot erode, something which ignores the eccentricities of
particular eras or moments...something that is truly timeless, this is the ultimate victory."
- Dr. Ing. h.c.F Porsche
Jump to top tdc is offline   Reply With Quote
Old Sat, Oct-13-2007, 02:14:04 PM   #9
mugenh22a4
เป็นคนจีน
mugenh22a4's Avatar
Reputation: 0 mugenh22a4 is on a distinguished road
Hong Kong
True tire pressure monitor systems have valve stems that measure air pressure and send a radio signal to a receiver mounted in the passenger compartment. This is the most direct way possible to monitor flat tires.
2008 ISF, Smokey Granite Mica on Black
[IMG]http://img25.imageshack.us/img25/780/dsc3038mod.jpg[/IMG ][IMG]http://img641.imageshack.us/img641/6913/dsc2821edited.jpg[/IMG ]
Jump to top mugenh22a4 is offline   Reply With Quote
Tire Pressure Monitor - How Does it Work? BestBMWCustomer E46 M3 (2001-2006) 5 Sun, Feb-27-2005 03:07:44 AM
Tire Pressure Monitor M3@NYC E46 M3 (2001-2006) 5 Mon, Aug-02-2004 10:20:33 PM
Tire Pressure Monitor Sensor In2Deep1080 E46 M3 (2001-2006) 3 Tue, May-25-2004 04:49:49 AM
tire pressure monitor sprinter E46 M3 (2001-2006) 17 Tue, Feb-03-2004 11:31:59 PM
Tire Pressure Monitor nyk08 E46 M3 (2001-2006) 9 Thu, Jun-19-2003 12:35:59 AM
Discussing Tire Pressure Monitor - How does it work? - Sensor in the tire? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
