Old Thu, Sep-14-2017, 02:00:51 AM   #1
Chapelle
Chapelle's Avatar
Reputation: 0 Chapelle is on a distinguished road
Default Camshaft Wear
I started my VANOS overhaul tonight. Good news is it looks like the hubs are still in tact at 87k miles.
However, I noticed these strange wear marks on some of the cam lobes which has me concerned.
Also, I noticed cylinders 4-6 spark plug gaskets had a small deposit of some kind of dirt/sand on one small side of the gasket. A small amount dropped onto the camshaft which I tried to gently wipe most of it out.
Has anyone experienced these events? Anything to be concerned about? I wasn't thrilled about the browning throughout. Oil changes he past two years of my ownership were done less than 3000 miles due to minimal driving and changes before winter storage. Great records from the last owner which indicates 5-6k mi changes. Last adjustment was done at 65k.
Jump to top Chapelle is offline   Reply With Quote
Old Thu, Sep-14-2017, 02:04:19 AM   #2
bigjae1976
Default Re: Camshaft Wear
If you're using TWS, you're engine will have a gold coating no matter how often you change oil.
I can't see anything odd on the cam lobes. Do the followers look OK?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Thu, Sep-14-2017, 02:38:07 AM   #3
Chapelle
Chapelle's Avatar
Not sure if you can see in the pics but there are some noticeable scratches. I didn't notice anything crazy on the followers but I'll see if I can snap a pic tomorrow.
Old Thu, Sep-14-2017, 05:05:44 AM   #4
Doesn't look bad too me, it's not even on the lobe really.
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav____________________JOURNAL
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped SS V1 S pipe + 200 cell HFC OE sect 2 SS Sport BMW Motorsport 4.10 Besian RE pullies/fan delete WPC rod bearings TMS Camber & Subf plates RE Trans Mounts AKG poly SUB/DIFF SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 440/550) + tall RSMs OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 ss brake/clutch lines Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Thu, Sep-14-2017, 01:13:02 PM   #5
bigjae1976
Looks like someone scratched at the TWS gold coating. I wouldn't worry about it.
Old Thu, Sep-14-2017, 06:24:03 PM   #6
10speed
Reputation: 0 10speed is on a distinguished road
My exhaust cam had wear like your 3rd pic from the top except a bit worse. I replaced the cam with another used OEM cam. If I had to do it again, I'd just put new Schricks in there
Your wear doesn't look too bad and I'd just check back in the next inspection.
Jump to top 10speed is offline   Reply With Quote
Old Thu, Sep-14-2017, 07:34:03 PM   #7
Chapelle
Chapelle's Avatar
Anybody have feedback for the small specks of dirt in pic 4?
Old Thu, Sep-14-2017, 07:39:38 PM   #8
bigjae1976
Random spooge from when you removed the valve cover? Don't think it's a big deal either. I would just use a shop vac to clean it up if it bothers you.
Old Fri, Sep-15-2017, 03:25:41 PM   #9
WyattH
Can this occur if the valves are spec'd on the tighter side?
Old Fri, Sep-15-2017, 04:18:07 PM   #10
Chapelle
Chapelle's Avatar
I was thinking the same. I'll let you know after I re-time and check clearances.
Discussing Camshaft Wear in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
