Old Wed, Sep-13-2017, 04:11:49 PM   #21
Default Re: Vanos splined shaft installation
Originally Posted by herrubermensch View Post
Fair enough, but that difference is not mechanically relevant to the operation of the vanos. I think we agree on that! From a mechanical relevance point of view, each spline is identical.
--Peter
Yep-- completely useless to worry about it/use it!
Old Wed, Sep-13-2017, 05:00:12 PM   #22
vwrado
Reputation: 0 vwrado is on a distinguished road
Thanks everyone! Now I feel much more confident with my install.
03.5 M3 Dakar Yellow | CSL intake | TTFS Tune | Ground control coilovers
00 M Coupe
Jump to top vwrado is offline   Reply With Quote
Old Wed, Sep-13-2017, 06:17:48 PM   #23
kuksul08
Originally Posted by ThunderMoose View Post
I use this one. Don't tell Raj.
The cam you're inserting splined shaft has to be in time (bridge tool in place). Once you get it in just push in far enough to where teeth are barely showing than torque and move to the next cam. If you push it any farther or less it will not pass vans test. Raj's method solves the exact amount of insertion by position of pistons on the back side but make torquing more complicated. No one that I know that follow's his procedure exactly have had any issues but I think the video is simpler and I have used it 4-5 times on my cars with no issue.
You have to be really careful to make sure you put it back the same way, making sure to account for the backlash in the splines.
Raj's method is best if you didn't know the exact starting position.
Old Thu, Sep-14-2017, 05:04:37 AM   #24
bimmerdriver
That's not correct-- the sweet tooth exists because there's a different number of splines in the curved portion than in the straight portion, so they don't align 1:1. The result is there's one spine that will slide in without rotating.
It's been a while since I had mine apart, but I don't think this is a correct statement. IRRC, you could rotate it more than one. The point is that the curved portion and the straight portion are not aligned so the hub has to rotate slightly.
Old Thu, Sep-14-2017, 11:23:36 AM   #25
You can rotate to any of the splines during insertion. You must always insert on the first available tooth. The "sweet tooth" is the spline at which the vanos hubs and cams align such that the splined shaft initially inserts without any counter clockwise rotation at all.
It's useless because the vanos has enough travel to carry out its complete range of advance/retard regardless of which tooth you start on-- be it the "sweet tooth" or the farthest from sweet tooth (the one that requires the most counter clockwise rotating before engaging the first tooth, while inserting the splined shaft).
Discussing Vanos splined shaft installation in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
