Old Wed, Sep-13-2017, 03:11:40 AM   #11
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Default Re: Vanos splined shaft installation
VIS XTS CF Hood - CF Lip/Console/Diffuser - OE CSL Trunk - Turner Spacers 15/12 - BWS 500S 11k/15k
Old Wed, Sep-13-2017, 04:21:34 AM   #12
bimmerdriver
Originally Posted by 02_LSB View Post
There is no trick to it. Insert into the first available spline. No such thing as sweet tooth. Follow raj's procedure and you'll be ok
I ran into the same issue while doing this job, but, in the end I followed raj's procedure without issues.
Scroll to post Number 9:
http://www.m3forum.net/m3forum/showthread.php?t=532100
This is the way to go. There is no "sweet tooth". When the hubs are torqued, it's the cams that are moving, not the hubs. If you follow Raj's procedure, the cam will be timed perfectly. It's easier to torque the hub bolts without the splined shaft installed, but if you torque the hubs before you insert the splined shaft, you will be guessing at the timing. If you look at the procedure in the TIS, it is similar to Raj's procedure because the hub bolts are torqued after the splined shaft is installed.
Old Wed, Sep-13-2017, 11:46:56 AM   #13
ThunderMoose
I'm just curious - What is the purpose of making cam marks on a variable valve timing engine?
I was under the impression that
timing is set down a few mm, so the even with marks, you're not putting splines back into the initial position.
It's just so you know which tooth you used. There is a sweet tooth but if you're a few teeth either side it will be fine. If you rotate the spline 180 from the sweeth tooth you will have to rotate the hub considerably to get spline to slide in. That could limit how much the cams can advance/retard.
#67 2017 NASA TX TT3 Champion
Old Wed, Sep-13-2017, 12:03:49 PM   #14
ThrowinShapes
ThrowinShapes's Avatar
Reputation: 0 ThrowinShapes is on a distinguished road
The sweet tooth has become this car's g-spot.
[06' AW/Cinnamon] [6MT] [Slicktop] [Manual Seats]
Journal - Update 2017-02-28
FS: Center Console | US Headers / Rear O2 | Rent: SIR B90-BMW Rear Wheel Bearing Tool
Jump to top ThrowinShapes is offline   Reply With Quote
Old Wed, Sep-13-2017, 12:14:12 PM   #15
The sweet tooth is 100% useless to do...
... and I do it every time
But, seriously, it is without benefit.
Old Wed, Sep-13-2017, 01:41:11 PM   #16
herrubermensch
herrubermensch's Avatar
Reputation: 0 herrubermensch is on a distinguished road
We follow the TIS procedure and use the BMW spacers and torquing sequence. Works every time. We have found no "sweet spot" that makes any difference at all, nor has my colleague, who designed and built dozens of these for Dinan over the years.
--Peter
Jump to top herrubermensch is offline   Reply With Quote
Old Wed, Sep-13-2017, 02:41:07 PM   #17
Ramp1
Ramp1's Avatar
Reputation: 0 Ramp1 is on a distinguished road
From a manufacturing standpoint, with all new parts, there is no sweet tooth. Anything remotely close to a sweet tooth is literally just wear in tolerance that makes one tooth clock in a few thou before another tooth. In the original factory assembly they just threw on the VANOS and grabbed the first tooth.
Jump to top Ramp1 is offline   Reply With Quote
Old Wed, Sep-13-2017, 02:47:10 PM   #18
herrubermensch
This!
--Peter
Old Wed, Sep-13-2017, 04:06:57 PM   #19
That's not correct-- the sweet tooth exists because there's a different number of splines in the curved portion than in the straight portion, so they don't align 1:1. The result is there's one spine that will slide in without rotating.
Old Wed, Sep-13-2017, 04:10:45 PM   #20
herrubermensch
Fair enough, but that difference is not mechanically relevant to the operation of the vanos. I think we agree on that! From a mechanical relevance point of view, each spline is identical.
--Peter
Discussing Vanos splined shaft installation in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
