Old Tue, Sep-12-2017, 10:19:48 PM   #1
vwrado
Reputation: 0 vwrado is on a distinguished road
Default Vanos splined shaft installation
When installing the vanos splined shaft into the hub, on Beisan it said "Rotate hub counter clockwise while pressing vanos onto hub.
Splined shaft will insert into hub at first alignment of splines."
I notice that when I insert the splined shaft before installing it on the vanos is that there is only 1 tooth that allow the splined shaft to travel all the way in the hub while the rest wouldn't allow it to be pushed all the way in. Does that mean that is the only tooth it should be installed in? Or it wouldn't really matter?
03.5 M3 Dakar Yellow | CSL intake | TTFS Tune | Ground control coilovers
00 M Coupe
Jump to top vwrado is offline   Reply With Quote
Old Tue, Sep-12-2017, 10:39:00 PM   #2
mdavidm3
Reputation: 0 mdavidm3 is on a distinguished road
Default Re: Vanos splined shaft installation
Doesn't really matter but there is also a "sweet tooth"
AKG||Euro Headers||Tilton Twin Disk Clutch||RTD||Mishimoto||Customized Bimmerworld Race Exhaust||Kirk Rollbar||Schroth||Sparco||Momo||OMP||Ground Control||Eibach||JRZ RSpro (rear coilover)||PFC Z31 BBK||Enkei NT03||Maxxis RC-1
Trackspec Autosports
MMI Vehicle Systems
Ravenol
IG: MD__M3
Jump to top mdavidm3 is offline   Reply With Quote
Old Tue, Sep-12-2017, 11:13:12 PM   #3
vwrado
The sweet tooth, that would be the one where the splined shaft can be pushed all the way in?
Are there any advantage of installing it in the sweet tooth?
I can't seem to get the timing right for the life of me. Using the cam timing tool and locking the crank, it seems the only other place I can mess up on is the vanos or am I missing something here?
00 M Coupe
Old Tue, Sep-12-2017, 11:49:27 PM   #4
Tp///M3
Got ///M?
Tp///M3's Avatar
Reputation: 0 Tp///M3 will become famous soon enough
Laos
Check out this thread but do not mix with Beisan procedure. Use one or the other.
http://www.m3forum.net/m3forum/showt...t=vanos+timing
04 CarbonBlack/ImolaRed
Jump to top Tp///M3 is offline   Reply With Quote
Old Wed, Sep-13-2017, 12:34:37 AM   #5
kokgo20
kokgo20's Avatar
Reach out to Dave, he is a master in this and probably can help you out.
You should be able to time the cams before installing the splined shaft, the sweet tooth is the one that you can get the shaft to sit all the way in as you mentioned, retime again, torque the gear bolts, retime again, ETC.
Build thread
05/2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - PF RTABs & FCABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - BMW MS 4.10 - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom A/F & boost gauge - Active Prima plus + FS tune - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast -
Jump to top kokgo20 is online now   Reply With Quote
Old Wed, Sep-13-2017, 12:35:10 AM   #6
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Take a look at the S54 Vanos Thread in my SIG.
Old Wed, Sep-13-2017, 01:45:36 AM   #7
02_LSB
There is no trick to it. Insert into the first available spline. No such thing as sweet tooth. Follow raj's procedure and you'll be ok
I ran into the same issue while doing this job, but, in the end I followed raj's procedure without issues.
Scroll to post Number 9:
http://www.m3forum.net/m3forum/showthread.php?t=532100
Jump to top 02_LSB is offline   Reply With Quote
Old Wed, Sep-13-2017, 03:10:39 AM   #8
ThunderMoose
I use this one. Don't tell Raj.
The cam you're inserting splined shaft has to be in time (bridge tool in place). Once you get it in just push in far enough to where teeth are barely showing than torque and move to the next cam. If you push it any farther or less it will not pass vans test. Raj's method solves the exact amount of insertion by position of pistons on the back side but make torquing more complicated. No one that I know that follow's his procedure exactly have had any issues but I think the video is simpler and I have used it 4-5 times on my cars with no issue.
#67 2017 NASA TX TT3 Champion
Old Wed, Sep-13-2017, 03:18:45 AM   #9
02_LSB
BMW S54 VANOS DIY - E46 M3, Z4 - YouTube
I'm just curious - What is the purpose of making cam marks on a variable valve timing engine?
I was under the impression that
timing is set down a few mm, so the even with marks, you're not putting splines back into the initial position.
Old Wed, Sep-13-2017, 03:29:28 AM   #10
legacyej25
Reputation: 0 legacyej25 is on a distinguished road
[/QUOTE]
I used this one along with the video ThunderMoose posted and it worked well.
2002 Carbon Black on Cinnamon
Jump to top legacyej25 is offline   Reply With Quote
Discussing Vanos splined shaft installation in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
