Old Tue, Sep-12-2017, 03:34:14 PM   #1
zippity
Reputation: 0 zippity is on a distinguished road
Default Hunting Idle and Stall
All, I have a combination of two common faults. A hunting idle on cold starts and a severe drop in rpm's when rolling to a stop. (Car would stall out completely if I don't blip throttle.) I have changed the MAF, Battery and Intake Filter. I don't know of any good ways to find a vacuum leak. I don't see any obvious cracks. I have tried the soapy water bottle trick to no avail. All help welcomed. Thx.
Jump to top zippity is offline   Reply With Quote
Old Tue, Sep-12-2017, 03:36:08 PM   #2
mdavidm3
Reputation: 0 mdavidm3 is on a distinguished road
Mine idle hunts and it's been getting more violent. It started when I got a lightweight flywheel. I'm going to raise my idle and hopefully that gets rid of it
AKG||Euro Headers||Tilton Twin Disk Clutch||RTD||Mishimoto||Customized Bimmerworld Race Exhaust||Kirk Rollbar||Schroth||Sparco||Momo||OMP||Ground Control||Eibach||JRZ RSpro (rear coilover)||PFC Z31 BBK||Enkei NT03||Nitto NT01||TTFS Tune||2800 lbs
Trackspec Autosports
MMI Vehicle Systems
Ravenol
IG: MD__M3
Jump to top mdavidm3 is offline   Reply With Quote
Old Tue, Sep-12-2017, 03:43:10 PM   #3
BearDeXPS
BearDeXPS's Avatar
Default Re: Hunting Idle and Stall
do you have a Dinan tune?
have you read/cleared codes?
is it switching to winter gas blend in your area?
is the air rail tube still connected?
have you checked voltage at the fuel pump?
have you changed fuel filter or replaced fpr?
have you cleaned your icv?
have you cleaned your itb's?
no miss fires?
have you checked your spark plugs?
coil packs still snug?
have you checked the elbow for any cracks?
there's too many things that are known to cause this issue... happy hunting
Old Tue, Sep-12-2017, 04:24:41 PM   #4
Drewster
Drewster's Avatar
smoke test will tell you if you have a vacuum leak most of the time
Old Tue, Sep-12-2017, 06:24:59 PM   #5
exodus454
Reputation: 0 exodus454 is on a distinguished road
Or brake cleaner/starter fluid/carb cleaner if you don't have access to a smoke machine.
I just recently smoked my engine and surprisingly my AFE intake has leaks at every joint (even though the clamps are as tight as they'll go)!
05 ZCP - 6MT >> CPI Stepped Headers - Magnaflow cats & 1 Cherrybomb - Meisterschaft Titanium - CSL software - Eibach pro kit - 15mm rear spacers - BW studs - GC Hybrid FCABS - BW Spherical RTABS - TMS front bar
Manual Leveling - Factory Xenon - Nightbreakers - ZKW-R lenses
Jump to top exodus454 is offline   Reply With Quote
Old Thu, Sep-14-2017, 11:03:50 AM   #6
zippity
[QUOTE=BearDeXPS;1067718925]do you have a Dinan tune?
No codes
Possibly, but it's been doing this all year.
I'm not familiar with the air rail tub. Where would I find this. I imagine it connects to the intake arm at some point.
I have a volt meter. How would I go about this?
I have not.
I did. I don't feel like it did much, if at all. I found that some just need to be replaced.
I did when I cleaned the ICV
no miss fires?
No
Replaced last year
I'll double check
I did. Nothing noticeable.
There are a lot of issues that can cause this...
Old Thu, Sep-14-2017, 11:05:24 AM   #7
zippity
Whats the proper way to do this test with carb cleaner etc..?
Old Thu, Sep-21-2017, 10:49:30 AM   #8
zippity
Old Thu, Sep-21-2017, 03:10:07 PM   #9
albino09
A Yankee South of the Mason-Dixon
I have the feeling I induced a hunting idle at cold start when I had trouble removing my fuel filter from the fpr. Try replacing both (or either). Both of your issues are occurring at low flow rates (coasting to a stop, idle speed) which could mean it just isn't moving enough fuel. Since you've replaced your MAF, checked your intake for leaks, and replaced spark plugs, the only remaining place to rule out is the fuel system.
1997 318i Silver/Black...Daily
Old Fri, Sep-22-2017, 12:18:02 AM   #10
exodus454
https://www.youtube.com/results?sear...h+carb+cleaner
Discussing Hunting Idle and Stall in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
