Old Tue, Sep-12-2017, 03:00:26 AM   #11
ReturnToS54
Reputation: 0 ReturnToS54 has disabled reputation
Default Re: Fuel smell near passenger rear well with car parked. No drip.
Which, if combined with a bad gas cap, makes sense then as to why the smell outside the car is particularly noticeable after hard driving. (Forced out of the tank and up the filler neck) Hopefully a new gas cap addresses the issue.
Jump to top ReturnToS54 is offline   Reply With Quote
Old Tue, Sep-12-2017, 09:33:20 PM   #12
englishtom1596q
englishtom1596q's Avatar
You would not get gas going that far up the filler neck unless you overfilled the tank (kept trying to put more gas in after it stopped automatically). Gas where you posted is normal after a fill up. It gets trapped between the gas cap and the flapper indicating your gas cap is sealing fine.
Old Wed, Sep-13-2017, 11:52:37 AM   #13
RND1
Reputation: 0 RND1 is on a distinguished road
I had gas leaking past the cap in hard left turns during autocross. Turned out to be evap purge solenoid located in the engine bay.
'98.5 M3 Estoril / Black 5sp - Summer Toy
'03 Toyota Land Cruiser - Adventure Rig
'11 Honda Ody EXL - Hers
Jump to top RND1 is offline   Reply With Quote
Old Wed, Sep-13-2017, 06:50:23 PM   #14
Jrrrrrrr
Unregistered User
Jrrrrrrr's Avatar
This point seems obvious, but hasn't been mentioned: are there any set or pending codes for a large or small leak, fuel-tank pressure sender, purge, or vent valves? I say this because the liquid-vapor condensation tank is right there in the right rear wheelwell, and being plastic, it is known to crack at the seems or suffer from broken line fittings. Such a problem would throw leak codes and probably a code for the pressure sender.
I am inclined to agree that even though it seems relatively implausible, if there are no evaporative system codes present, the problem would have to be fuel or condensed fuel vapors leaking up the filler neck and past the gas cap.
Old Wed, Sep-13-2017, 08:46:34 PM   #15
ReturnToS54
No check engine light. Do you think it would be worthwhile to get a code reader, or would these codes cause the CEL to definitely appear?
Old Mon, Feb-26-2018, 08:13:17 PM   #16
JaBron_Lames
Reputation: 0 JaBron_Lames is on a distinguished road
Did you ever track down this issue? Finding similar symptoms in my '97 as well. Brand new BMW gas cap did not solve; also seeing fuel present in the lower portion where the cap screws in as you were regardless of when it was last filled.
Jump to top JaBron_Lames is offline   Reply With Quote
Old Mon, Feb-26-2018, 08:38:47 PM   #17
The problem was fixed on my friends car. It was that beige/white nipple with the arrow on the hose in the first pic. The plastic nipple was torn. Lower that tank and inspect more thoroughly.
Old Tue, Feb-27-2018, 05:04:11 PM   #18
JaBron_Lames
Sweet I will get on that, thanks Braymond.
Discussing Fuel smell near passenger rear well with car parked. No drip. in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
