Old Tue, Sep-12-2017, 01:59:22 PM   #21
SQ13
Default Re: Steps to take to ensure flood car doesn't run into issues?
Originally Posted by bigjae1976 View Post
Just PM me your address and I'll send it. What year is your car?
PM sent
Originally Posted by aab010799 View Post
Wow man I am so sorry.
Do not give up on the car though!! Not worth it to give up a nice example. Very nice car
The car will probably live.
Old Tue, Sep-12-2017, 07:59:58 PM   #22
idntknow2005
idntknow2005's Avatar
Reputation: 0 idntknow2005 is on a distinguished road
I work with electric motors that cost 30-50k and are not designed to get wet, however they are constantly getting wet and the electrical box would fill with water. Obviously it ruins the motor and it used to ruin the power leads. So we started using a terminal gel, since then we haven't had any issues at all. Im willing to bet if you let the car dry out and put some gel into the connectors that did or even could get wet that you would be fine.
Here is a link to the terminal gel, it's super cheap and it really works
https://www.rvwholesalers.com/parts/...iABEgJ7S_D_BwE
2001 E46 ///M3 - LSB+ on Cinnamon - Full Restoration "Brought back from the dead"
Jump to top idntknow2005 is offline   Reply With Quote
Old Tue, Sep-12-2017, 09:32:38 PM   #23
qualicas
qualicas's Avatar
You are one of the lucky ones of sorts re cars. There are about 10,000 cars out at the race track in Baytown. Can't imagine the misery of having to redo the
house. My son in law's father's house was flooded in Baytown. Anyway back to the point, this is one of those times when WD40 is actually a thing to use. It is designed to displace water so I would use it on some connectors that are wet and maybe use a contact cleaner after they dry.
Old Wed, Sep-13-2017, 05:23:06 PM   #24
SQ13
The wiring looks fine, but I will keep the dehumidifier in there and keep inspecting. I'll look into the WD40 and terminal gel methods.
Currently fighting with insurance on a fair market value. Their initial offer won't even get me a high mileage M3 in shitty condition. And the ****ers adjusted/lowered the "listed price" of a local car and included a car that doesn't even exist (verified using VIN) on their retarded valuation report.
Old Wed, Sep-13-2017, 05:26:08 PM   #25
bigjae1976
Which insurance company?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Wed, Sep-13-2017, 05:29:18 PM   #26
SQ13
Geico
Old Tue, Oct-03-2017, 03:18:44 PM   #27
SQ13
Should rear wheel bearings be replaced because they were submerged in water?
Old Tue, Oct-03-2017, 03:22:06 PM   #28
bigjae1976
Yes. The grease is likely contaminated.
I have the SIR B90 tool for rent. I can cut you a break on the rental fee.
You should by a good set of c clip pliers or youíll be using a dremel to cut out the c-clip.
Iíd get on that soon because itís gonna be a massive B if that starts to rust up.
Do you still need those airbag sensors? I finally found them this weekend.
Old Wed, Oct-04-2017, 02:58:22 PM   #29
SQ13
I won't be able to get to it for a few months. Car is stored and won't be driven for a while. I was thinking about having a shop do the work. I'll let you know if I'd like to rent the tool.
Shop didn't tell me that the sensors need to be replaced. I'll have to read codes to see if there are any problems with the sensor.
Last time I was near the car, the battery kept draining. I replaced the two year old battery, but that didn't help. I'm thinking it might have been caused by the removal of the OBD cover? Hopefully something else isn't drawing power. Will have to investigate further.
Old Wed, Oct-04-2017, 03:39:47 PM   #30
bigjae1976
Default Steps to take to ensure flood car doesn't run into issues?
There is probably a switch or relay that is closed causing something to be powered up. Water is conducts electricity...
Might be DSC/ABS related?
Discussing Steps to take to ensure flood car doesn't run into issues? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
