Old Fri, Sep-08-2017, 01:37:05 PM   #1
SliM3
SliM3's Avatar
Default E85 and Catch Can Recovery
Hey guys need a little assistance identifying the liquid I drained from my catch can.
I'm running E85, with AFR's averaging 13. During cold starts at 65-degrees and below, I'll hit about 10 on start-up and it'll bump up to around 11-11.5 for warm-up & settle in at idle around 14-14.7.
I know E85 is hygroscopic and I expected more steam from the tail pipe, but after about two days of driving I dumped this from my catch can:
Would this be considered normal quantity, and, why does it look like a urine sample?
Also, should I send it to Blackstone for analysis, or don't waste my time?
///M3 '06 Carbon Black
-Benjamin Franklin
- Fuel adaptations explained
- Checksum Verification
Old Fri, Sep-08-2017, 01:44:25 PM   #2
Drewster
Drewster's Avatar
Default Re: E85 and Catch Can Recovery
It's pretty normal for catch cans to get a decent amount of water in them - simple condensation from the air, not necessarily anything that has to do with your fuel. I wouldn't worry about it too much as long as it still smells a bit like petroleum byproducts
Old Fri, Sep-08-2017, 02:47:48 PM   #3
SliM3
SliM3's Avatar
Cool thanks. Yeah it definitely smells like petro byproduct.
-Benjamin Franklin
Old Fri, Sep-08-2017, 03:01:16 PM   #4
skillzo1
skillzo1's Avatar
Reputation: 0 skillzo1 is on a distinguished road
Mine looked exactly the same
Current 05 IB//BL 6SPD 714RWHP 590TQ
SOLD 05 AW//IR 6SPD
Skillzo's Build...http://www.m3forum.net/m3forum/showthread.php?t=487768
Jump to top skillzo1 is offline   Reply With Quote
Old Fri, Sep-08-2017, 03:17:06 PM   #5
stash1
Hey Brian, I think that's relatively normal for some, but mine has the more typical espresso latte look to it...I have the old HPF set up and I've noticed that mine fills almost completely up after just a few hundred miles of driving. Amazing how much crap these "catch" cans actually trap inside!
'04 AW/IR...Not Stock
Old Fri, Sep-08-2017, 03:58:52 PM   #6
HassanEido
HassanEido's Avatar
Lebanon
Weird. I must've had a crappy catch can,coz for 6months it stayed mainly empty, apart from a few droplets of oil
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
364.1 whp 287.8 wtq
Old Fri, Sep-08-2017, 08:30:16 PM   #7
stash1
Maybe you're not driving it hard enough!?
Old Fri, Sep-08-2017, 09:57:02 PM   #8
bigjae1976
I'm used to seeing milky brown stuff that smells like fuel.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Fri, Sep-08-2017, 11:34:52 PM   #9
ThunderMoose
That's what I see in my catch can running 93 pump gas
#67 2017 NASA TX TT3 Champion
Old Fri, Sep-08-2017, 11:35:47 PM   #10
bigjae1976
Are there a lot of people using catch cans on NA engines?
Discussing E85 and Catch Can Recovery in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
