Old Tue, Sep-05-2017, 03:25:53 PM   #1
m333fun
m333fun
Reputation: 0 m333fun is on a distinguished road
Default Best keyless entry e36 ?
Looking to find the best keyless entry for 1997 sedan. Just purchased the car and dialing it in! Thanks
Jump to top m333fun is offline   Reply With Quote
Old Tue, Sep-05-2017, 06:07:21 PM   #2
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Default Re: Best keyless entry e36 ?
Best would be the factory system, not offered in the US.
Bonus is the keyfob that comes with it.
Old Tue, Sep-05-2017, 09:06:25 PM   #3
This is what you want; http://unitedautosecurity.net/BMW-E3...aspx?sid=13867
Stick to the E46 Diamond Key.
Old Fri, Sep-08-2017, 12:38:55 AM   #4
jabwind51
jabwind51's Avatar
Reputation: 0 jabwind51 is on a distinguished road
I bought exactly this and it thing seemed awesome at first but is garbage. My keys stopped starting the car (but would still lock and unlock) only 2 weeks after installing this...And customer service has not been helpful. The only thing I can gather is the EWS chip inside the key fob is not receiving a charge so I have opened the keys and re positioned it several times to no avail.
I wouldn't endorse this product at this time.
1997 BMW M3/4/5
1990 BMW E30 325iS (M3 Evo Sport Replica Build)
2017 Fiat Spyder Abarth
2015 Subaru WRX (sold)
2010 BMW "130is" (sold)
2002 E46 M3 sMg (sold)
2001 Jeep Liberty (sold)
Jump to top jabwind51 is offline   Reply With Quote
Old Fri, Sep-08-2017, 09:28:00 AM   #5
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
The EWS chip does require power. It can't magically transmit data without a power source.
There is an inductive coil and capacitor inside the EWS chip.
The EWS ring atenna around the ignition lock induces AC power to the coil and charges the capacitor inside the transponder chip.
E36 does have an induction coil to charge the capacitor
Old Fri, Sep-08-2017, 10:22:21 AM   #6
jabwind51
jabwind51's Avatar
Interesting...But then it does use power via the ring or no?
If my valet and wallet key still work they obviously are oriented correctly so my ignition lock isn't broken I would presume.
1997 BMW M3/4/5
Old Fri, Sep-08-2017, 12:57:02 PM   #7
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
The transponder chip is just one EWS component. Could be several other bits. Could be the antenna ring/coil the EWS module or the transeiver box under the steering column.
So with these custom keys, did you have to insert the original chips or what?
But if your valet/spare keys work (start the car) there is nothing wrong with your EWS.
Old Fri, Sep-08-2017, 01:07:58 PM   #8
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
To answer your Q. Yes it uses power. If the capacitor is not charged, the chip an't communicate.
Old Fri, Sep-08-2017, 04:27:52 PM   #9
Dee514
Dee514's Avatar
Reputation: 0 Dee514 is on a distinguished road
Tibet
Any preference of why the diamond key instead of the flip key?
Thanks
Jump to top Dee514 is offline   Reply With Quote
Old Fri, Sep-08-2017, 04:36:38 PM   #10
Thanks
You don’t drive a VW.
Discussing Best keyless entry e36 ? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
