Old Sat, Sep-02-2017, 08:19:17 PM   #1
M-technik-3
Default Very strange steering issue
So yesterday, I took an E36 out for a test drive, owner said the steering was super tight and tough, I was like yeah ok drive a car with no PS too myself.
Get in the car drive to bottom of driveway and attempt to turn right, that right attempt to, pull the wheel with some serious effort thinking it was just low on fluid and the pump might be cavating NO drove up the street mile and come back thinking WTF is wrong with this car. Made an offer based on this car is not safe to drive on street until it's fixed.
Reservoir had fluid in it and there was no leaks under the car, hoses reversed or wrong banjo bolts? It's feels like it's binding then lets go then binds again. Strange.
Thoughts? Opinions
Old Sat, Sep-02-2017, 08:49:16 PM   #2
westopher
westopher's Avatar
Default Re: Very strange steering issue
Are there any sounds involved? I had HORRIBLE low speed steering when my front strut mounts went bad because the shocks were binding so hard.
98 m3, techno/anthrazit cloth, 103k and officially worthless. 2000 323i touring, silver/grey/sport pack, 170k and officially boring.
Jump to top westopher is online now   Reply With Quote
Old Sat, Sep-02-2017, 09:32:48 PM   #3
M-technik-3
No none, it's odd. I know it's going to have to go on the lift and figure it out. Thought it might have to do with the E46 M3 wheels in 18's but not even at speed did the issue go away.
Old Sat, Sep-02-2017, 10:32:15 PM   #4
I've experience this on someone's M3 with a completely blown out power steering system. It just needs to all be replaced.
Fluid in it doesn't mean anything. Someone could have run power steering fluid in and burned up the pump (calls for atf). Just expect to replace everything and possibly the rack. Not a huge deal.
Old Sun, Sep-03-2017, 12:23:58 AM   #5
M-technik-3
Yeah I gave a lower number based upon this, I hope it's just that nothing more. Thinking of putting an faster rack in it.
Old Wed, Sep-06-2017, 03:08:59 AM   #6
McGyversM3
Reputation: 0 McGyversM3 is on a distinguished road
I just refreshed my steering shaft I was experiencing similar issues with my 97 coupe. Except I was getting a springy noise when turning.
I changed my clock spring and I still had the issue. So I assumed it was the rack power steering pump. But I change my rack less than a year ago and the pump was silent. I put the car on the lift and when I looked at the firewall where the steering shaft protrudes from I saw a rusty spring and circle. I read on a forum the that s a bearing that seizes up and makes it hard to steer. So to test it out I soaked the bearing in JB80 and then took the car for a test drive the noise was gone and the steering was free.
I changed the upper and lower bearing and while I was in there I replaced the rubber flex joint for the rack to the shaft with an all metal u joint from the e34.
Jump to top McGyversM3 is offline   Reply With Quote
Old Wed, Sep-06-2017, 07:57:19 PM   #7
M-technik-3
Oh I hope it's not that bad would rather just swap out power steering pump and I had just ordered a ZHP 712 rack last week.
Old Sun, Sep-10-2017, 10:26:54 PM   #8
PITT M3 RR
PA
PITT M3 RR's Avatar
There's an adjustment on the rack that people tighten...compresses the pinion to the shaft and causes this. Also, there's solid chance the CV joint in the steering arm is seized. Mine was on half the joint and would bind at three points in travel.
Used Z3 rack and new shaft made the car feel new.
All info https://www.bimmerforums.com/forum/s...2#post29718722
S54 E36 BUILD
Old Sun, Sep-10-2017, 11:50:09 PM   #9
M-technik-3
yeah That is a thought as well and a simple check. My ZHP rack arrived yesterday for it.
Old Mon, Sep-11-2017, 10:51:35 PM   #10
scoobiedoo2029
Reputation: 0 scoobiedoo2029 is on a distinguished road
i tried no PS once. it was a huge mistake. i then screwd the alignment changing parts and the car felt terrible, i didnt even want to take it out of the driveway. anything wrong in the steering is over exaggerated without powersteering,
the upper steering shaft ujoint likes to seize as well, id assume it can get very very tight.
its easier to diagnose with the parts in your hands. just tear it down move it all around. if its a mechanical issue itll be quickly apparent. it its the rack there cheap to replace now.
Jump to top scoobiedoo2029 is offline   Reply With Quote
Discussing Very strange steering issue in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
