Old Tue, Aug-29-2017, 10:57:07 PM   #11
Default Re: Sanity check - Cam spocket
11 inch lbs is nothing. Put your finger in there and you can easily push the guide as far as it will go.
Old Tue, Aug-29-2017, 11:11:05 PM   #12
Why even use your finger if the tensioner is stronger than that...
Old Wed, Aug-30-2017, 01:30:25 AM   #13
I don't think anything more is needed. It seems so simple to me but maybe I am missing something. If the exhaust sprocket arrow is lined up with the edge of the head, you are good.
Old Wed, Aug-30-2017, 02:38:42 AM   #14
JitteryJoe
I thought the point of the chain pre-load is to set the tension on the main drive part of the exhaust cam sprocket and chain (the side opposite of the chain tensioner). Once the sprocket is bolted down the tension on that side is set (no slop) and the temporary chain tensioner is removed to be replaced by the permanent one. This keeps the timing of the exhaust cam & crank from drifting due to any unwanted chain slop. The operational chain tensioner is simply to take up residual slack on the non-drive side and keep the chain from jumping any teeth. Is this correct?
I don't see why the exhaust sprocket arrows really matter as long as the cam holes line up to the left side of the sprocket slots. Those slots are perfectly symmetrical so I don't see how the orientation of the arrow makes any difference.
Like I said, this is new to me but looking at it off and on again for a few days, that is my impression. But please correct me if I am wrong. Learning is a good thing.
Thanks,
Joe
Old Wed, Aug-30-2017, 04:15:02 AM   #15
The arrows DON'T mean anything as your view on them is purely subjective. They are used to keep consistency in setting everything up so you know the operation of everything (once bolted down correctly) is going to function as intended.
TIS calls for the air tool. Use the air tool. Don't do it by hand and don't just look at the arrows and say "good enough". I know this isn't a hard job, but with all of the posts that come up over the years with VANOS timing issues, just go by the book... it will not fail you.
The tension on the chain is to keep the eventual lockdown of the exhaust cam in time with the bottom end. You can see the elongated holes on that exhaust sprocket Joe posted just how much room you have to play with to lock the cam in place. That's a lot of area to get wrong too.
Old Wed, Aug-30-2017, 12:28:05 PM   #16
Lining up the arrows with the edge of the head is not required but BMW put them there because doing that makes the job a little quicker if you use bmw's timing method. There are other timing methods that work but for those who are uncertain of their work or want verification, the BMW way is best. I might use the air tool to test my work sometime when I am looking for a project rather than trying to get through existing ones. I want to see how far off I am. When I did my first one in 2006, we used the air tool to verify travel and were in the specified range.
Old Wed, Aug-30-2017, 04:02:21 PM   #17
JitteryJoe
Is there a definitive guide on how to set up the vanos other than what is in the Bentley book? There are several YouTube vids but I don't know which ones to trust.
Thanks!
Joe
Old Wed, Aug-30-2017, 05:59:52 PM   #18
http://www.adkusters.dsmynas.com/Web.../11_31_505.pdf
Old Wed, Aug-30-2017, 06:43:43 PM   #19
JitteryJoe
Many thanks!
Discussing Sanity check - Cam spocket in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
