Old Thu, Aug-24-2017, 04:16:10 AM   #1
mauromj
Reputation: 0 mauromj is on a distinguished road
Default Front swaybar end links hitting struts?
I just recently put my front subframe back under my M3 after replacing all the bushings and ball joints. Now at full lock, the front sway bar end link is making contact with the wire/cable mount on the strut.
Green arrow indicates where the contact is happening. (Both sides)
Anyone have the same issue?! I don't understand what I am doing wrong!
BTW, this is a pic off of Google images. Its not my car. I have all stock M3 components.
Jump to top mauromj is offline   Reply With Quote
Old Thu, Aug-24-2017, 04:53:30 AM   #2
mauromj
Default Re: Front swaybar end links hitting struts?
This is where it gets strange.
One strut is marked left, but the cable/wire mount is welded onto it such that it belongs on the right (driver side) (2 holes - brake pad wear sensor, and brake line).
The other strut is marked right, but the cable/wire mount is welded onto it such that it belongs on the left (passenger side) (3 holes - brake pad wear sensor, ABS, and brake line).
So I guess the question is, should the cable/wire mount face on the front of the strut (closest to the front bumper in terms of direction), or on the back of the strut (closest to the back bumper in terms of direction.
Currently, I have it such that it faces back (like i the pic). This is how I have seen every car setup online.
If this is correct, it sounds like AST welded on the tab mounts on the wrong sides and I have the struts mounted on the wrong sides.
Old Thu, Aug-24-2017, 05:56:02 AM   #3
Are you messing up left and right? Left is drivers side and vice-versa.
Google E36 struts to better help yourself.
Old Thu, Aug-24-2017, 10:28:00 AM   #4
LockDots
LockDots's Avatar
The tabs should be facing the rear of the car.
Jump to top LockDots is online now   Reply With Quote
Old Fri, Aug-25-2017, 12:03:50 AM   #5
mauromj
This is how they are, but they are hitting at full lock?!
I have the car on jack stands, maybe with a load applied, they will clear?
Old Fri, Aug-25-2017, 10:34:31 AM   #6
LockDots
LockDots's Avatar
It's possible. The angle of the suspension system is changed while up in the air. It's also possible your tabs are bent.
Old Fri, Aug-25-2017, 01:04:19 PM   #7
jayjaya29
Photographer
jayjaya29's Avatar
Bend the cable/wire mount a bit to clear the endlink.
Old Sun, Aug-27-2017, 05:57:07 PM   #8
Earthwormjlm
Imolarot M3
What is up with your control arm, that doesn't look stock, that looks like an E46 arm. Don't those increase your track width and lock?
Old Sun, Aug-27-2017, 07:00:53 PM   #9
Vitaliy93
Reputation: 0 Vitaliy93 is on a distinguished road
Is there a rule on this forum that says you should read the post before commenting? Well there should be.
Sent from my SGH-M919 using Tapatalk
Jump to top Vitaliy93 is offline   Reply With Quote
Old Sun, Aug-27-2017, 09:25:45 PM   #10
Earthwormjlm
Imolarot M3
Yeah there should be... No one is allowed mistakes either apparently.
I guess I figured why would someone post a picture that doesn't show their problem on their car.
Maybe mauromj's sway bar isn't centered? There's not a lot of clearance between the tab and sway bar on my car.
Discussing Front swaybar end links hitting struts? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
