Old Mon, Aug-21-2017, 01:39:50 AM   #1
turge
turge's Avatar
Reputation: 0 turge is on a distinguished road
Default Rough Idle E36 M3 (95 OBDI)
So I'm having an issue with my idle on my 95 M3. The car is OBD1, and sadly it is autotragic. I keep getting the 1262 error code for my ICV. I've put in a brand new ICV and I'm still getting the error. We tried unplugging the idle control valve to see if that fixed anything and the check engine light subsequently went away. At that point my idle was hovering around 500 RPM. We test drove it around the block, see video below, and it ran better. I still have some lifter tick but I think that's from the car sitting idle for like 6 months. When you do the stomp test, the code still comes up after the check engine light was removed, but it doesn't show up when driving. I think maybe the wiring is bad for the idle control valve, but I'm not sure. Let me know what you guys think the issue is with the car. Trying to get it so I can pass smog. Thanks.
Sent from my SM-N920T using Tapatalk
Jump to top turge is offline   Reply With Quote
Old Thu, Aug-24-2017, 01:17:09 AM   #2
LuckyM301
LuckyM301's Avatar
Reputation: 0 LuckyM301 is on a distinguished road
Default Re: Rough Idle E36 M3 (95 OBDI)
reset the battery and see if that deletes the code, if you replaced and the code only comes up on stomp test pretty sure it just needs a reset to delete the stored code
Sent from my SAMSUNG-SM-G890A using Tapatalk
Jump to top LuckyM301 is offline   Reply With Quote
Old Tue, Aug-29-2017, 05:36:04 AM   #3
turge
turge's Avatar
It didn't delete the code so I ended up swapping the DME / ECU with a known working one. Turned out something was bad with my original unit. Car runs good now but after driving it for a bit, got the O2 Sensor code. Swapping that with a good unit I have lying around and fingers crossed that all the issues are gone.
Discussing Rough Idle E36 M3 (95 OBDI) in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
