Old Wed, Sep-06-2017, 05:49:59 PM   #31
kyrix1st
kyrix1st's Avatar
Japan
Default Re: Front control arm ball joint
I suppose the best option is 3.0 offset CAB+ 3.2 control arms for the max positive caster.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Rear: Stock-Endless CC-RG //
Recaro SPG, SR-2//
Sparco 35cm steering//
Hella headlights//
Old Wed, Sep-06-2017, 08:21:35 PM   #32
bluptgm3
Default Front control arm ball joint
Most people who have done something similar (1996+M3 Spindle/King Pin/FLCA + 1995M3 Offset FLCABushing) generally go back to 1996+M3 Centered FLCABushings due to rubbing issues and too much caster.
Old Thu, Sep-07-2017, 03:10:42 PM   #33
kyrix1st
kyrix1st's Avatar
Japan
The 1996+M3 King Pin/Spindle has a corresponding lug revision to match the change in ball joint location in the 1996+M3 FLCA.
How bad does it rub? I'm running 235/40/17.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Recaro SPG, SR-2//
Hella headlights//
Old Fri, Sep-08-2017, 01:03:17 PM   #34
bluptgm3
I varies depending on wheel width, offset, and thickness of spacer used.
Old Sat, Sep-09-2017, 05:36:09 PM   #35
kyrix1st
kyrix1st's Avatar
Japan
I currently run 15mm spacers front for Brembo F40 BBK + style 24 wheels (option aluminum alloy) which IIRC has an offset of 38. Planning to give -2 to -2.5 camber on each side with +1.5 caster and little bit of toe out depending on how it drives. Would this rub?
WTB: Carbon airbox
'98 M3 evo (S50B32)
Recaro SPG, SR-2//
Hella headlights//
Old Sat, Sep-09-2017, 05:44:09 PM   #36
bluptgm3
I cannot speak to your specific set-up, but my guess is yes. It is better to go to camber plates IF you think you need more caster. Not sure how much more you can get with Camber Plates however.
Old Sun, Sep-10-2017, 10:54:25 AM   #37
Hasan Shaikh
Reputation: 0 Hasan Shaikh is on a distinguished road
United Arab Emirates
I would also suggest going with camber/caster plates. At least you can dial back a bit if it rubs too much.
Jump to top Hasan Shaikh is offline   Reply With Quote
Old Sun, Sep-10-2017, 11:05:06 AM   #38
Hasan Shaikh
How are you planning to increase the camber?
Old Sun, Sep-10-2017, 02:01:52 PM   #39
kyrix1st
kyrix1st's Avatar
Japan
Swapped strut mount works the best it seems.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Recaro SPG, SR-2//
Hella headlights//
Old Sun, Sep-10-2017, 06:21:30 PM   #40
bluptgm3
Swapped 1996+M3 Bearing Plates/Guide Supports.
ball joint, e36 suspension, front, press
Discussing Front control arm ball joint in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
