Old Sat, Aug-19-2017, 11:38:04 AM   #1
kyrix1st
kyrix1st's Avatar
Japan
Default Front control arm ball joint
I've seen some threads on guys replacing with E30 or E46 Meyle HD ones, but none of them seem to state "fits M3 models". Does anyone know what the mechanical difference is between non-M and M control arms?
WTB: Carbon airbox
'98 M3 evo (S50B32)
Rear: Stock-Endless CC-RG //
Recaro SPG, SR-2//
Sparco 35cm steering//
Hella headlights//
Old Sat, Aug-19-2017, 02:39:10 PM   #2
bluptgm3
E36 non-M Forward Lower Control Arms contain an isolated outer ball joint and fit in a 46mm hole.
E36 M FLCA have a solid outer ball joint and fit in a 41mm hole.
E30M3 steel and aluminum FLCAs have solid inner BJs and solid outer BJs (and same geometry as E36 318/323/325/328 and 1995 M3.)
The press in replacements from the E30 are both solid and fit in the 1995M3 and 1996+M3 FLCAs.
However, geometrically, the 1996+M3 FLCA has different geometry than the E36 318/323/325/328 and 1995 M3.
I have not seen firm confirmation that the E30 BJs fit in the outer BJ location of the E36 non-M FLCAs.
I also don't have conformation the inner E30 BJ is smaller than the E36 Non-M and/or E36 M FLCA.
My understanding is that the E30 M3 FLCAs are the same geometry as the 1995 E36 M3 FLCAs, something has to be different as they both have solid BJs but carry different p/n's.
The guys replacing the BJs of their E36 M3 FLCAs (both 1995 and 1996+ model year arms) feel confidant that there is no issue.
https://www.bimmerforums.com/forum/s...ement-with-E30
https://www.bimmerforums.com/forum/s...E36-M3-spindle
Old Sat, Aug-19-2017, 08:56:34 PM   #3
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Default Re: Front control arm ball joint
And just for the record. 3.2 control arms are totally different from M3 3.0/non-M, as it's shaped to increase caster.
On side pics you can see the front wheel on 3.2's isn't centered and also has wheelbase listed as 2710mm vs 2700mm for all other E36's.
Old Sat, Aug-19-2017, 08:57:22 PM   #4
The ball joints fit and are the same size. Many of us have been using this method to refurbish the arms for years (credit to whoever figured it out). There's no difference in the ball joint, only the arms differ.
Old Sun, Aug-20-2017, 02:47:48 PM   #5
Jrrrrrrr
Unregistered User
Jrrrrrrr's Avatar
One user PMed me claiming he attempted the DIY replacement, but found there was a difference in the balljoint bore size for the front control arms of his 1995 car. That was the one contrary account I've ever seen on this subject, and I bet if that user had a problem, there was some other explanation like 3-series control arms on his/her M3, or buying the wrong P/N balljoints.. The overriding consensus of 1995 owners in the DIY thread is that the physical difference between 1995 and 96-99 front control arms doesn't matter - the bore sizes for the balljoints are the same, so the 31121126254 and 31121126253 balljoints press into all of the 1995-1999 e36 M3 FCAs.
http://www.m3forum.net/m3forum/showthread.php?t=402063
Old Sun, Aug-20-2017, 05:10:51 PM   #6
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Of course does the physical difference matter.
They each use different control arm bushings. You can't just mix stuff.
Old Sun, Aug-20-2017, 06:20:42 PM   #7
bluptgm3
Yes the 10mm added length negates the need for Offset FLCA Bushings for caster.
Additionally, the Spindle/Kin Pin lower pad for the two strut attach bolts grew in thickness adding ~ 1 degree of camber (for increased King Pin Inclination which increases camber at full steering lock.) The Guide Supports/Bearing Plates for 3.2L 1996+M3 have been modified to negate the added Spindle/King Pin camber (and some) by moving the strut shaft outboard. Swapped Guide Supports/Bearing Plates add additional camber stated previously.
245/40-17 tires on 8.5 inch rims with ET41 backspace need spacers to fit on 3.2L 1996+M3, spacers not required for same on 3.0L 1995M3.
Old Sun, Aug-20-2017, 09:22:13 PM   #8
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Yes the kingpin/hub is also different and so are the topmounts.
I use the 3.0 setup on my 328i, solid balljoint control arm, topmounts and excentric lower bushes. Stock hub/kingpin. Added the reinforcement plates.
My 3.2...well it uses the factory setup.
Old Sun, Aug-20-2017, 10:54:08 PM   #9
NLZN
NLZN's Avatar
Reputation: 0 NLZN is on a distinguished road
Pressed new balljoints on my m3 over the winter myself, running them all season thrashing in autox.. so far, no problems.
Jump to top NLZN is offline   Reply With Quote
Old Mon, Aug-21-2017, 12:45:41 PM   #10
Jrrrrrrr
Unregistered User
Jrrrrrrr's Avatar
Obviously I was only talking about the physical differences in the '95 and '96-99 FCAs not mattering in terms of balljoint fitment.
ball joint, e36 suspension, front, press
Discussing Front control arm ball joint in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
