Old Tue, Aug-15-2017, 11:33:22 AM   #11
Default Re: Collapsed lifters- bad cam trays? Or VAC S54 oil pan upgrade?
I'd love to see someone measure the difference in output between the VAC modified pump and the stock pump. Based on VAC's other products, I wouldn't be surprised if it was less than stock.
Old Fri, Aug-18-2017, 02:46:52 PM   #12
vmbray
Reputation: 0 vmbray is on a distinguished road
I have stock internals, 160k, s54 pump, pan. Depending on the course I will have lots of ticking at autocross. One thing that helps is let the engine idle between runs. If you shut it down, it seems that the valves that are open mash the lifters and force the oil out. I have a lot less issue with this if I let it idle. Opening the hood isn't a bad idea to help with heat soak. And yes run a solid quart high.
Sent from my SM-N910V using Tapatalk
Rear End Overhaul
Jump to top vmbray is offline   Reply With Quote
Old Fri, Aug-18-2017, 04:19:14 PM   #13
BobInIndy
Reputation: 0 BobInIndy is on a distinguished road
I do appreciate the comments about running a quart over, and ticking being common with these cars, especially from someone running an S 54 pump and pan. However, what I'm experiencing is not just ticking, but actual physical collapsing of the lifter, such that when I remove it, is collapsed a 10th of an inch or so and does not extend.
Bob
Jump to top BobInIndy is offline   Reply With Quote
Old Tue, Aug-22-2017, 01:53:27 AM   #14
BobInIndy
So, to update this thread. I pulled the cams , trays and lifters. Two are collapsed on the intake side this time. But now, a new finding. The thrust surface at the front part of the cam has been grinding against the front cap of the intake cam tray. These are both wearing surfaces, and are totally wrecked. Now there is about 1/8 inch or more of cam end play. I don't see an oiling problem on the cam bearing journals. Just faint wear. Either the cam had a bad thrust surface, or somehow the vanos was ramming the camshaft back. Is that even possible?
Bob
Old Tue, Aug-22-2017, 05:01:08 AM   #15
All I hear is don’t buy Riot cams.
Discussing Collapsed lifters- bad cam trays? Or VAC S54 oil pan upgrade? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
