Old Tue, Aug-01-2017, 10:52:00 PM   #1
Schitzel
Reputation: 0 Schitzel is on a distinguished road
Default Brake light issue PLEASE HELP
Whenever I apply the brakes, the tail lights go out and the LED strip in the center illuminates. When the pedal is released, the tail lights illuminate and the LED strip goes out.
I'm looking for someone to help with the coding remotely, any other ideas as to what could be causing this?
2003.5 Jet/Cinn 6MT
Eibach Borla Rouge Beisan Powerflex Valentine SPAL
Jump to top Schitzel is offline   Reply With Quote
Old Tue, Aug-01-2017, 11:16:35 PM   #2
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
Default Re: Brake light issue PLEASE HELP
Check your brake lights switch
Tischer aka GetBmwParts
Old Wed, Aug-02-2017, 01:53:19 AM   #3
djjvr
OEM+
djjvr's Avatar
Denmark
OP, unless you coded something that wasn't mentioned in your initial post this is a possibility.
"Sucking at something is the first step to being sorta good at something!"
Build Journal
Old Thu, Aug-03-2017, 12:31:30 AM   #4
yco
Reputation: 0 yco is on a distinguished road
Turkey
E46 is weird with its electric system.. even BM53 can get affected from speedometer.. just guessing can be a outdated brake sensor, faulty connected rear lights or most of the leds are dying in those rearlights especially turning signals.. if none of them will help i have another idea i ll tell..
Jump to top yco is offline   Reply With Quote
Old Tue, Sep-12-2017, 08:20:26 PM   #5
Schitzel
It was related to coding
Fixed with NCS dummy!
Now to figure out how to inactivate burble/pop so that I can pass emissions
2003.5 Jet/Cinn 6MT
Discussing Brake light issue PLEASE HELP in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
