Old Mon, Jun-12-2017, 05:08:11 AM   #1
///Minivan
Reputation: 0 ///Minivan is on a distinguished road
Default Strange heater problem
My heater doesn't seem to work. Yah, I know, summer is here and I live in SoCal but it bugs me. Here are the symptoms:
Good
- Blowers work
- HVAC panel buttons all function normally
- A/C works great
Bad
- When I bumped up the temp to around 76 degrees, it really made no perceptible difference from the outside air temp.
- When I spin the center vent "temperature wheel" from blue to red - the air goes from icy cold (max blue) to no air coming out at all (max red).
I think this last symptom is probably the most telling. I'm guessing that I'm not the first person to run across this. Curious to know the likely cause and whether it's a DIY fix.
Jump to top ///Minivan is offline   Reply With Quote
Old Mon, Jun-12-2017, 07:13:39 AM   #2
Default Re: Strange heater problem
It's your heater valves.
New;
Aftermarket rebuild kit;
Old Mon, Jun-12-2017, 03:58:06 PM   #3
///Minivan
Thanks, I'll get it looked after.
Old Tue, Aug-29-2017, 03:26:10 PM   #4
///Minivan
I got a new heater valve installed.
Still have a doubt/question...
Scenario:
- Set temp to 70F on both sides
- Face and Feet vents on
- A/C off
- Blower turned up beyond half-way
- Progressively turn "middle vent wheel" from max blue to max red
- Airflow from Face vents goes down to almost nil (Feet vents don't change)
Is it normal operating behavior?
Now here's the kicker. If I jack up the temp to 80F+, the airflow from the Face vents *doesn't* change.
Old Wed, Aug-30-2017, 01:54:18 PM   #5
wgknestrick
Reputation: 0 wgknestrick is on a distinguished road
I have similar functionality in mine. Heater only works on floor, not middle vents. Same issue? Needs new heater valve?
Jump to top wgknestrick is offline   Reply With Quote
Discussing Strange heater problem in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
