Old Wed, Feb-08-2017, 01:38:17 AM   #1
irex511
Reputation: 0 irex511 is on a distinguished road
Default UUC Short Shifter / DSSR Position Question - Seems too far back
Hey Folks,
I'm mid install on the UUC Short Shifter and DSSR on my 2011 M3. I have everything mounted and before putting it all together wanted to see what you guys thought of the positioning.
It seems like it's leaning too far towards the rear of the car but I'm not sure what I could have messed up in the install if anything? The shifter on my e46 stood straight up and down. Can anyone that has the shifter confirm if this looks correct?
It shifts smoothly but my wrist seems to bump the idrive knob going into second..
Neutral
Second
Cheers,
Mike
Sent from my Pixel using Tapatalk
2006 BMW M3 ZCP - 6MT, TCK D/A Coilovers, TCK Camber Plates, PowerFlex RTABs and FCABs, PFC Carbon Z Brakes, SS Lines, Schroth Harness, Bridgestone Potenza RE-11s
Jump to top irex511 is offline   Reply With Quote
Old Sun, May-21-2017, 07:24:02 PM   #2
blastpanel
Reputation: 0 blastpanel is on a distinguished road
Default Re: UUC Short Shifter / DSSR Position Question - Seems too far back
Did you find out what the issue was with your UUC shifter? I just had mine installed and it is angled the same way. The shifter functions well but the ergonomics are odd.
Jump to top blastpanel is offline   Reply With Quote
Old Sun, May-21-2017, 07:34:30 PM   #3
irex511
Yep, I contacted Rob at UUC and it turns out it was a defective part. Here it is now (with the correct shifter installed) in Neutral, First, and Second. I have mine at close to stock height.
Hope this helps and best of luck! It's a great shifter now that it's right!
Discussing UUC Short Shifter / DSSR Position Question - Seems too far back in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
