Old Sat, Jan-28-2017, 06:17:01 PM   #1
#1P4PKing
Driving Enthusiast
#1P4PKing's Avatar
Reputation: 0 #1P4PKing is on a distinguished road
Question Replacement Battery: Any aftermarket recommendations?
Hey all,
I have been getting a battery draining while car is off alert lately, and while doing some research online, this can be several different things, I have decided to replace my battery.
Poking around here and other forums, the cost + labor to install a new OEM is like 500 USD, and it seems many people recommend getting a "lightweight" aftermarket replacement.
Can anyone shed light on this? What brands are recommended, are lightweight batteries just lighter?
Any additional pros and cons here?
Thanks!
Jump to top #1P4PKing is offline   Reply With Quote
Old Wed, Feb-01-2017, 01:59:43 AM   #2
Mfanaticnyc
Mfanaticnyc's Avatar
Reputation: 0 Mfanaticnyc is on a distinguished road
Default Re: Replacement Battery: Any aftermarket recommendations?
Not sure bout lighter ones but pretty much batts are made by 2-3 companies. Get one with the best warranty and have it coded.
Jump to top Mfanaticnyc is offline   Reply With Quote
Old Wed, Feb-01-2017, 02:07:17 PM   #3
I used an Autozone AGM battery. I forget the model, but think it is H8. All the warranties are really 3 years now. The stock and aftermarket ones weigh about 60 lbs. The car is power hungry and I think a lower capacity one won't last as long and could be risky in severe cold or if you let the car sit for a week at a time without using a charger. If you don't drive your car in winter, or keep it on a trickle charger, a lower capacity one might be fine for a few years. I forget the models for the lower capacity batteries, but it might be H6 and I think you can even run a Mini battery if the car is really a warm weather trickle charger car. I drive my car year round, so I bought the full size AGM replacement.
Old Wed, Feb-01-2017, 05:50:55 PM   #4
04yfz
http://shop.advanceautoparts.com/p/a...49h8/2130012-P
Use coupon code TRT30 to get $50 off and do local pick up. New battery with higher capacity for approximately $110. Code and register with an indy or private guy for another $50-100.
Pat - Proud E46 Addict
2002 M3 Tiag/Imola Coupe-6MT (SOLD)
2005 325xi Tiag/Tanin - 5MT (SOLD)
2006 M3 Silvergrey/Black Coupe (SOLD)
2006 M3 Tiag/Black Coupe - 6MT (SOLD)
2003 330i ZHP 6MT ---> S54/M3 Conversion (build coming soon)
Old Tue, Mar-28-2017, 06:22:48 AM   #5
jjrho
Reputation: 0 jjrho is on a distinguished road
i always buy AGM batteries now; lasts longer, maintenance free…
btw, why do you have to 'code' when changing a battery?
I just undid my neg.side for about 30min. to take the air bag down and reconnected the batt; not a single issue….???
james
08 e92 m3 44k miles
Jump to top jjrho is offline   Reply With Quote
Old Tue, Mar-28-2017, 11:49:27 AM   #6
Code if changing the amp hours of the battery. Otherwise reset battery adaption.
Old Sat, Apr-01-2017, 07:01:22 PM   #7
Mfanaticnyc
All batteries are the same just look at CCA and warranty, have it coded also. You can diy just don't go to the dealer. There are better brand if you are looking to save on weight.
S65 E90 LCi SG/FR M3
Old Sat, Apr-01-2017, 07:18:55 PM   #8
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
Default Replacement Battery: Any aftermarket recommendations?
Pep boys - Bosch 3 different CCA
Tischer aka GetBmwParts
Old Sat, Apr-01-2017, 07:32:09 PM   #9
admranger
Registered troublemaker
Originally Posted by daytonaviolet View Post
Pep boys - Bosch
I used this one. Black friday sale was really good. Always look at pep boys online for coupons and then buy online with in store pick up. It's cheaper than going to the store and buying one. Not sure why they do this but they do...
'11 E90 M3, Melbourne/Black/Fox Red/Black, 6MT, roof, PP2, heated seats, Eibach Pro Kit, GC Street camber plates, Arc-8's, Technic harness, JL XD 600/6
Old Sat, Apr-01-2017, 09:05:43 PM   #10
Just buy an AGM, which is an H model or will have an AGM designation. Those all look pretty close in spec but only 2 are AGM. I think the H8 is stronger than stock and ideally would get coded; the Group 49 AGM is close enough to stock to drop in and just reset battery adaption.
battery, bmw, e92, replacement
Discussing Replacement Battery: Any aftermarket recommendations? in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
