Old Sat, Mar-25-2017, 12:27:02 AM   #91
SunD3v1L
hi
SunD3v1L's Avatar
Reputation: 0 SunD3v1L is on a distinguished road
Italy
Default Re: F10 M5 knob & boot install in e46 M3
Originally Posted by westsidebalto View Post
Ah, I didn't think about leather break in. Plus it's still only 40 degrees and colder at night here in the Northeast. A few hot summer days with the top down will give a little stretch to that leather.
Great write up by the way. The clothespin part was genius!
Thanks dude, enjoy
Jump to top SunD3v1L is offline   Reply With Quote
Old Mon, May-29-2017, 04:51:49 PM   #92
Edgy
Constantly Learning M3 and M5 Owner
Edgy's Avatar
Reputation: 0 Edgy is on a distinguished road
Default Shining Bright!
Finally pulled the trigger, and really happy with the results. Thanks again for the excellent thread - will throw props your way when I write this up for my site.
FWIW - I found that the issue between the F10 and E46 base rings wasn't really size, but different shape. I didn't have a lot of excess boot to deal with, which was OK since I didn't want the leather edges too close to the console clips. Ring removal and shift knob removal were easier than I thought going in.
Only thing I'd add from a DIY perspective is make sure you disconnect the fuse prior to pulling the knob off. Easily done by pulling up on base and following wire to plug.
So much nicer that stock broom stick, and much brighter too.
BLUE HEAVEN:
Interlagos 2006 M3, AutoLogic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Conforti/Shark tune. MRegistry listing here
Jump to top Edgy is offline   Reply With Quote
Old Mon, May-29-2017, 05:54:15 PM   #93
e46IX
e46IX's Avatar
Reputation: 0 e46IX is on a distinguished road
Has anyone weighed the F10 M5 shift knob in comparison to say ZHP or BMW Performance?
Jump to top e46IX is online now   Reply With Quote
Old Mon, May-29-2017, 08:58:00 PM   #94
02_LSB
Yes.
http://www.m3forum.net/m3forum/showthread.php?t=363268
Jump to top 02_LSB is online now   Reply With Quote
Old Wed, Sep-13-2017, 05:04:56 AM   #95
jealeman
Reputation: 0 jealeman is on a distinguished road
Great write up. I just did this swap and followed your instructions to the letter. Much better than the broomstick.
1996 Cosmos Black M3, HKS Klasse Exhaust, Dinan Cold Air Intake, Dinan Stage 2 Engine Software, Luxury and Competition Package (slat grille, not mesh). Sold 2007.
2006 Carbon Schwarz Metallic Dinan S1-M3 ZCP
Best. Car. Ever!
Jump to top jealeman is offline   Reply With Quote
Old Wed, Sep-13-2017, 06:58:17 PM   #96
SunD3v1L
hi
SunD3v1L's Avatar
Italy
Good to hear! Mine's still going strong after how ever many years ago I wrote this up.
Old Wed, Sep-13-2017, 10:18:34 PM   #97
Poowill
Poowill's Avatar
Reputation: 0 Poowill is on a distinguished road
Good Write up - However I still managed to mess this up!
Here's a few tips.
1. When using glue, cover/tape/bag the knob because if super glue gets on the leather surface of the knob, it WILL NOT come out. I was so mad at myself when I got two spots on my brand new knob and tried everything to get it out.
2. Make sure you have enough material on the bottom left and right of the ring to allow it to go into 5th gear AND Reverse! I was trying to pull down as tight as possible so that there would not be any bulging and that was a mistake.
After I got over the fact I had glue on the knob I installed it. 1st gear, 2nd...3rd... oh yea this thing is awesome!...4th....... 5th aaaaandd it pops out of the ring!!
Can anyone provide some good instruction on how to re-use the old leather boot? At this point it's my only option other than getting another one and trying again.
1998 e36 M3 - Sold | 1991 e30 325iX - Sold | 2002 e46 330xi - RIP | 2008 e92 328xi - Sold | 1990 e30 325i Sold
2001 e53 X5 Daily
2005 e46 M3 IB/Cinnamon ZCP 6spd
Jump to top Poowill is offline   Reply With Quote
Old Fri, Sep-15-2017, 06:15:28 AM   #98
RyanAllison
RyanAllison's Avatar
Reputation: 0 RyanAllison is on a distinguished road
Anybody offering this as a service? I'm not handy nor do I have the time to complete this task...also I'm not handy....
2016 BMW M3 ZCP & 2006 BMW M3 ZCP
Jump to top RyanAllison is offline   Reply With Quote
Old Fri, Sep-15-2017, 07:43:51 AM   #99
SunD3v1L
hi
SunD3v1L's Avatar
Italy
Here's a few tips.
I'll also warned of not leaving enough slack to get into reverse. It'll loosen up over time, but you need to be careful about placement.
Old Fri, Sep-15-2017, 08:42:06 AM   #100
L0ADED
L0ADED's Avatar
There is a rubber cement glue that is yellow in color and it is very similar to what they use from the factory. It will allow for mistakes since it can be easily removed before it completely drys. Super glue will just make a mess and will ruin anything it comes in contact with.
As for making sure the boot is properly positioned, just have the two stitched lines equally spaced from the two upper corners of the shift boot. I have seen a few examples where the person lined up one corner with the stitched line and the other was way off; it did not look good being asymmetrical, and I believe getting reverse was a problem.
diy, f10 m5 knob, someone will complain
Discussing F10 M5 knob & boot install in e46 M3 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
