Old Wed, Sep-06-2017, 03:30:44 PM   #541
03FLBimmerm3
Reputation: 0 03FLBimmerm3 is on a distinguished road
Hello Guys, I'm in the process of sourcing all of parts needed for my conversion..when it comes to the bellhousing parts listed below, which line items are mandatory if I buy the bellhousing myself versus modifying? (Most likely with purchase bellhousing from Kevin on this forum) Thank in advance for all your help!
The Parts List:
Bellhousing and Transmission Parts
List #PartSourceSource P/NBMW P/NQTYPriceExt. Price
16MT Transmission BellhousingForumsNANA1$200.00$200.00
2Locking PinGetBMWParts 231112229791$12.88$12.88
3Compression SpringGetBMWParts 233112283931$4.32$4.32
4Sealing CoverGetBMWParts 231275274392$4.59$9.18
5Lock RingGetBMWParts #071199346242$1.69$3.38
6Locking PinGetBMWParts 233112241301$11.10$11.10
7Compression SpringGetBMWParts 231112227201$8.99$8.99
8Torx Screw, micro-encapsulated M8x25GetBMWParts 233175866371$2.57$2.57
9Comrpession SpringGetBMWParts 233175113371$5.88$5.88
10Compression SpringGetBMWParts 233112284051$5.75$5.75
11Gear Identification SwitchGetBMWParts 231422291131$78.02$78.02
12Cable ClampGetBMWParts 117875472131$0.30$0.30
13Cable ClipGetBMWParts 345211646531$0.30$0.30
14Pentosin MTF2 (OEM Fluid)ECS Tuning *832203090312$22.50$45.00
15Locking PinGetBMWParts 233175015841$20.83$20.83
16Thrust PinGetBMWParts 233112824441$11.49$11.49
     Trans. Parts Total: $419.99
Jump to top 03FLBimmerm3 is offline   Reply With Quote
Old Sat, Sep-09-2017, 01:21:32 PM   #542
bigo1087
Reputation: 0 bigo1087 is on a distinguished road
Originally Posted by kaiv View Post
Thanks!
Hey Josh; I can check for the harness tomorrow if you want. And yes I should be around Saturday. You going to the autocross?
If you use the 6 speed Harness, does this avoid any splicing of wires for the clutch switch?
2006 IB ZCP| 6MT | H&R| SGT Scorza| TTFS | Turner | JVT| Dinan | AKG |
Jump to top bigo1087 is offline   Reply With Quote
Old Sun, Sep-10-2017, 08:23:42 PM   #543
A little bit. Not all of the clutch wiring is part of the engine harness. This is the factory manual circuit:
https://www.newtis.info/tisv2/a/en/e...switch/qhdL9rk
You'll have to splice from an existing connection for power (Pin 3) and ground (Pin 2) - haven't looked at the DIY, but I imagine the brake switch is the easiest splice point. And you have to run a wire from pin 4 of the clutch switch to pin 8 of the EWS module (if a US car and you want to have the clutch interlock).
Pin 2 is where the engine/transmission harness gets involved. On a factory manual car, Pin 2 of the clutch switch is run to Pin 7 of the X6011 connector here.
The engine harness will then have a small section coming off it that takes the connection from X6011 (black 8-pin block) to X6053 (white 8-pin block). There should already be a gray wire running there.
The manual harness will be able to handle the rest of the routing from there (X6053 -> Gear recognition sensor -> DME X60002 / Pin 20).
If you don't get a manual harness, you'd have to do that last leg of routing yourself.
If it were me, I'd not bother retrofitting the gear recognition sensor. Instead I would run the clutch wire to X6011 Pin 7, and then add a wire going from the male end of X6053 Pin 5 directly to the DME. And then do the coding to get the DME to recognize that. Or even bypass that bit of wiring and go directly from clutch switch to DME
Old Tue, Sep-26-2017, 08:22:03 PM   #544
GiaK
Reputation: 0 GiaK is on a distinguished road
Hi, you don't seem to list parts #17 - 20 from the transmission diagram, are these parts not needed for conversion? As in, are they already present on SMG?
Repair kit, locking - 2331750694
Hex bolt. M6X18 - 23317545769
WAVE WASHER. B6 - 23317545770
Cap - 23211222729
Thanks!
Jump to top GiaK is offline   Reply With Quote
Old Wed, Sep-27-2017, 08:31:49 AM   #545
mitesh33
Reputation: 0 mitesh33 is on a distinguished road
United Kingdom
I agree you donít need the Manual Harness, itís more work than itís worth to remove and install the manual one.
With regards to the wiring. You need proper e46 M3 clutch switch in order for cruise control to work, any other e46 clutch switch will not work.
As Terra said there is no reason for Gear Identicaion Snesor, my cruise control works flawlessly without it, when cruise control is running and soon as you press the clutch or brake it disingages it as it should.
Wiring:
If you haven't installed the Gear Position Sensor (GPS) on the transmission then to make cruise control work, you need to run a wire from the Clutch switch Pin 2 -> X60002/Pin 20
Really not necessary to wire the clutch switch EWS module, we in Europe donít have that feature and personally never see the point.
The other two pins from the clutch switch, just tap into the corresponding two wires on the brake switch, the diagram is in the first post DIY.
Car: 2002 E46 M3 Individual Coupe
Exterior: Individual Estroil Blue / Genuine CSL 19s
Interior: Individual Two Tone Gray/Black Leather
Engine: OEM
Suspension: OEM
Exhaust: OEM
Jump to top mitesh33 is offline   Reply With Quote
Old Fri, Sep-29-2017, 03:46:17 AM   #546
ExclusiveAuto
Reputation: 0 ExclusiveAuto is on a distinguished road
for those that have done this, is it possible to keep (modify) the smg bell housing? if so, can you provide in detail what must be done? Im sure it was discussed in 55 pages, but I was not able to find it. Thanks.
Jump to top ExclusiveAuto is offline   Reply With Quote
Old Fri, Sep-29-2017, 09:32:04 AM   #547
ebmw21
Reputation: 0 ebmw21 is on a distinguished road
http://www.m3forum.net/m3forum/showthread.php?t=475959
BBS LM / ST suspention / Bee-r Intake / AP V1 / CPI Rasp Terminator / CSL SMG Coding / CSL Bumper
Insta: @jstrattn
Vancouver BC area ECUWORX coding avalable.
Jump to top ebmw21 is offline   Reply With Quote
Old Fri, Sep-29-2017, 02:38:53 PM   #548
ExclusiveAuto
Originally Posted by ebmw21 View Post
amazing. thank you!
Old Fri, Oct-13-2017, 07:04:41 PM   #549
2003wmb
Reputation: 0 2003wmb is on a distinguished road
Another option is to keep the SMG just as it is and get a CAE shifter and re-code the car. The shifter has all the proper springs and adjustments to make it work. Pretty amazing, although you have to drop about 1k for the shifter.
Have a look at this built in europe on m3cutters.
http://forums.m3cutters.co.uk/showth...=166606&page=2
Jump to top 2003wmb is offline   Reply With Quote
Old Mon, Oct-30-2017, 11:43:11 PM   #550
Turb02
Turb02's Avatar
Has anyone done this swap and installed the RTD shifter at the same time?
I need to do this in the very near future and am trying to figure out what parts are NOT needed from the parts list.
Any assistance would be greatly appreciated.
Active Autowerke Stage 2-AA Headers-Meisterschaft-Vorsteiner-Brembo-BBS-CSL
Jump to top Turb02 is offline   Reply With Quote
