Old Mon, Aug-07-2017, 05:15:56 AM   #31
Chaz17
Chaz17's Avatar
Reputation: 0 Chaz17 is on a distinguished road
Default Re: E36 M3 three spoke steering wheel swap
Would this wheel be a direct fit for my 95 m3? Would it just require wire splicing or a new clock spring/other parts?
https://www.ebay.com/itm/112499728042
Jump to top Chaz17 is offline   Reply With Quote
Old Mon, Aug-07-2017, 05:35:43 AM   #32
westopher
westopher's Avatar
The second post in the thread explains in detail what you need to know.
All I know for sure without reading through all of it is you need a new turn signal bracket, slip ring, wheel, and airbag.
98 m3, techno/anthrazit cloth, 103k and officially worthless.
Old Mon, Aug-07-2017, 06:00:24 AM   #33
Chaz17
Chaz17's Avatar
I read that through a few times and am still not positive lol.
Old Thu, Aug-10-2017, 11:42:01 PM   #34
Oogie_M
o_O
Oogie_M's Avatar
Reputation: 0 Oogie_M is on a distinguished road
Taiwan
None are a direct fit unless you have a 95+ non-M3 or M3 with 3/98+ build date.
For 94 and all M3's
(cars using slip ring '804):
These cars use a slightly different stock slip ring (airbag connectors are different from 92-93 but same as '95-on). However, the horn circuits are the same as the 92-93 E36's.
This means you'll only need to splice into the horn wire on the new '111 slip ring and replace the steering column switch bracket. The airbag connector will be a direct plug-in, saving time.
The procedure is the same as above, omitting airbag wire splicing (most of steps 6-9). Easy!
Exceptions to the '95-on procedures: some convertibles thru '97 may have used slip ring '804, and M3's from 3/98 use slip ring '111 and are therefore plug-n-play.
Jump to top Oogie_M is offline   Reply With Quote
Old Fri, Aug-11-2017, 12:50:35 AM   #35
Chaz17
Chaz17's Avatar
So for a 95 M3 I'd just need to splice in the horn wiring and get a new switch bracket then?
I'll understand this soon, I swear.
Old Fri, Aug-11-2017, 02:53:32 AM   #36
qwkslvrnsx
Reputation: 0 qwkslvrnsx is on a distinguished road
From my understanding, YES, as long as the upgraded 3 spoke wheel comes with its clock spring.
Jump to top qwkslvrnsx is offline   Reply With Quote
Old Fri, Aug-11-2017, 03:07:31 AM   #37
Chaz17
Chaz17's Avatar
Awesome.
Old Fri, Aug-11-2017, 01:41:41 PM   #38
M3n00b
M3n00b's Avatar
North Korea
Originally Posted by NNJL View Post
I think I got everything figured out. The clicking noise turned out to be the wire from the clock spring was a little loose.
shitty iphone pics but,
before:
after:
The wheel tired turned out better than expected, after 15 minutes of cleaning all the grime off.
I have the same wheel/airbag sitting in a box...can anyone tell me which parts I need to buy?
Do the following only apply to the euro wheel?
Slip ring, p/n 32 34 1 162 111, $175 list
Steering column switch bracket, p/n 32 31 1 162 088, $3.79 list
Old Fri, Aug-11-2017, 03:55:58 PM   #39
westopher
westopher's Avatar
They apply to any 4 spoke to 3 spoke swap.
Old Thu, Sep-07-2017, 07:52:37 AM   #40
TheDukeGTi
Reputation: 0 TheDukeGTi is on a distinguished road
Originally Posted by Sirius View Post
Here's a DIY I wrote up years ago when I did my swap. Has all the info you need + pics.
http://www.m3forum.net/m3forum/showt...ighlight=wheel
This is for sure the DIY to follow. I did this exact swap on my 96 and had zero issues thanks to this DIY.
I made sure to get the correct bracket and slip ring as indicated in the DIY.
Sirius, if you're still around and reading this. Big thanks sir!
Jump to top TheDukeGTi is online now   Reply With Quote
Discussing E36 M3 three spoke steering wheel swap in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
