Old Mon, Aug-28-2017, 07:21:30 PM   #731
Toxic0n
Default Re: The Official E46 M3 Oil Analysis Results Thread
[quote=TboneM3;1067711882]
Originally Posted by Toxic0n View Post
Well, here is my first report. First time using M1 0w40 in my car, didn't like it and will be switching back to 10w60.
QUOTE]
What didn't you like, looks like a great report.
I ran a VANOS test in DIS and it failed the inlet leak test by just a hair over 5 degrees two out of four times.
Ran the same test on 10w60 and it passed 4 times in a row.
Coincidence? Or thicker oil? Not sure, but I will stick with 10w60 for now.
Ground Control, Mason Engineering, HRE, ACS, Rogue Engineering
Jump to top Toxic0n is offline   Reply With Quote
Old Mon, Aug-28-2017, 07:21:51 PM   #732
Toxic0n
Old Wed, Sep-13-2017, 09:47:09 PM   #733
///M3 MD
Reputation: 0 ///M3 MD is on a distinguished road
Default The Official E46 M3 Oil Analysis Results Thread
Here's my first analysis. Bought the car with 98k, oil change every 5-5.5k miles with Liqui moly 10w-60. Rod bearing recall done at 25k by original owner, now at 113k. Is it time to change the rod bearings based off the lead and copper levels?
Edit: Or can I wait to do another oil change/analysis and trend the numbers?
2002 Carbon Black/Black 6MT ///M3
Mods: (Mike Miller Maintenance schedule) - Euro Headers - Resonated Section 1 - Dinan Section 3
TTFS Custom Tune
Autosolutions 30% SSK - RE Poly Trans mounts - AKG Poly diff bushings, RTABs and FCABs
Dinan 'Stage 1' Suspension
Jump to top ///M3 MD is offline   Reply With Quote
Old Wed, Sep-13-2017, 10:25:09 PM   #734
binary
Reputation: 0 binary is on a distinguished road
Ok finally hosted my first picture. Bought the car a few months ago and just hit 100k. There was approximately 6500 miles on this sample. I barely drive the car and plan to change every 5k.
Any help you experts can provide would be awesome. Looks like lead is high and copper is low? What does that mean, any red flags? I have no idea if the previous owner used additives but I do know that track fuel wasn't used before it reached me.
Jump to top binary is offline   Reply With Quote
Old Wed, Sep-13-2017, 10:37:07 PM   #735
Good
@GOOD_M3
Good's Avatar
Was a little concerned, hopefully another oil change will clean out the system. Unsure of how frequent previous owner conducted his oil changes.
EXTERIORJCSL 1X1 DIFFUSER | VÖRSTEINER CSL BUMPER
PREVENTATIVE ▌VANOS BEISAN LOCKDOWN: UPPER GUIDE CHAIN | SOLENOID COIL PACK | OIL PUMP DISK | SMG PUMP/MOTOR RELOCATED
EXHAUSTSUPERSPRINT EXHAUST ~ OVERSIZED STEPPED V1 HEADERS | RACE CATTED SEC 1 | RESONATED X-PIPE SEC 2 | SPORT (GEN 2) SEC 3
BRAKES ▌STOCK CSL/ZCP ROTORS | PORSCHE 996 BREMBO CALIPERS | SS LINES
WHEELS ▌STOCK ZCP BBS 19" | 75MM ECS/TMS F&R WHEEL STUD CONVERSION
SUSPENSIONTURNER MOTORSPORT 30MM FRONT SWAY BAR | KW V2 COILOVERS | GROUND CONTROL CAMBER PLATES | SDW RTABS
ENGINE ▌TUNED BY PAUL-CLAUDE | KARBONIUS CSL AIRBOX (ALPHA N), OEM SNORKEL (FLAP DELETE), OIL CATCH CAN
TRANSMISSION ▌'255' CSL SMG DME TUNE | INERTIA SMG DME UPDATE | WARM-UP LIGHT RECALIBRATION
Instagram: https://www.instagram.com/good_m3/?hl=en
Youtube: https://www.youtube.com/channel/UCOW...3N7QDfZ5NSzriA
Journal: http://www.m3forum.net/m3forum/showthread.php?t=599036
Old Mon, Sep-18-2017, 01:27:30 AM   #736
exodus454
Reputation: 0 exodus454 is on a distinguished road
My oil samples have had copper and lead dancing around for awhile now. I don't know why Blackstone assumed I was using race gas or octane booster, my car has never seen either.
I finally got to bearings this weekend, there's quite a few with copper showing! I've been babying the engine the past few months. I'm REALLY glad to finally have this done. My car just hit 146k. No knowledge of prior replacements. My car seems to have spent most of it's life doing trips up and down the east coast, maybe they're original. They had BMW part numbers.
I replaced mine with ACL + OE bolts
Found this in my oil pan.. I'm assuming it looks like a piece of timing guide? I tried looking up the front of the engine after I found it and didn't see anything. PO rebuilt the vanos so maybe maybe it's leftover?
Also intriguing, almost all of the bolts were stretched/torqued slightly differently. One of the bolts the blank spot in the middle was barely elongated, some others definitely show some slight narrowing of the shanks like it might have been overdone. The detorque values across all of them were anywhere from 65nm to 85nm.
I thought the angle sequence was supposed to alleviate this kind of thing
Makes me curious if that was a contributing factor to how unevenly worn some of them are, a few of them were significantly easier to remove.
05 ZCP - 6MT >> CPI Stepped Headers - Magnaflow cats & 1 Cherrybomb - Meisterschaft Titanium - CSL software - Eibach pro kit - 15mm rear spacers - BW studs - GC Hybrid FCABS - BW Spherical RTABS - TMS front bar
Manual Leveling - Factory Xenon - Nightbreakers - ZKW-R lenses
Jump to top exodus454 is offline   Reply With Quote
Old Tue, Sep-19-2017, 10:01:00 PM   #737
M3_Pilot
This is Castrol's latest Supercar oil. I am definitely going to get another sample at 4,000 miles.
2004 Jet Black/Cinnamon 6MT
@jet.m3
Old Tue, Sep-19-2017, 10:24:55 PM   #738
TheSt|G
Resident Curmudgeon
TheSt|G's Avatar
Isle of Man
Definitely looks like you are up for rod bearings.
911 Journal/Build Thread
Old Wed, Sep-20-2017, 12:55:30 AM   #739
M3_Pilot
I certainly agree with you. However, don't you think you my wear levels are higher because I had a longer interval than the universal average?
@jet.m3
Old Wed, Sep-20-2017, 01:42:28 AM   #740
jxnguyen
Reputation: 0 jxnguyen is on a distinguished road
Just recently picked up an 04 m3. First day I owned it I did the oil change and analysis. This is what I got. Thoughts? I've since babied the car since getting the results back (driven slow and under 4k) and I am about to come close to the 1k mark and getting the oil sent in again. Is it possible the elevated levels are from an oil additive? Will post analysis when I get the oil results back.
Jump to top jxnguyen is offline   Reply With Quote
Discussing The Official E46 M3 Oil Analysis Results Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
