Old Tue, May-22-2012, 03:36:35 PM   #1
ed007
ed007's Avatar
Reputation: 0 ed007 is on a distinguished road
Default Aluminum vs Plastic Thermostat Housing
I thought I should share this with anyone who wants to "upgrade" to aluminum thermostat housing.
After running an aluminum thermostat housing for a while I am convinced now that it is best to stay with plastic OEM and just change it every 60,000 miles or so. First, I thought the upgrade will be better, but these MTC or URO Parts aluminum housings are of terrible quality. I just returned a URO Parts housing that I had ordered because it looked very poorly made and my first thought was: "There is no way I am putting this thing in M3 cooling system that is run by a $200 Stewart pump."
The MTC part that I had in my car always had strange leaks no matter how many times you change the seals. So, I went back to plastic OEM, and all the leaks are gone.
Nothing against aluminum housings, but the ones that are currently sold as aftermarket parts have just too poor quality (uneven surfaces, inside cracks etc).
Someone mentioned once that the best part for a BMW is the one that BMW engineers designed for it or at least approved it as OEM. I am now a believer.
Jump to top ed007 is offline   Reply With Quote
Old Tue, May-22-2012, 03:48:01 PM   #2
fiveightandten
fiveightandten's Avatar
Default Re: Aluminum vs Plastic Thermostat Housing
Agreed. The Al housings that are being made currently are garbage. I had one that was cracked right out of the box. I replaced it with another Al housing because it was what I had available locally. It's still on my car, but next time I'll be going with OEM.
-Nick
Old Tue, May-22-2012, 03:51:20 PM   #3
M3n00b
M3n00b's Avatar
North Korea
Had an AL ronak for a year...then it started leaking...went with oem.
Old Tue, May-22-2012, 04:24:23 PM   #4
scoobiedoo2029
Reputation: 0 scoobiedoo2029 is on a distinguished road
bought an aluminum one from pelican parts, and it leaked, drowning it in RTV sealant fixed it but still its not supposed to leak, i wish id bought another oem one, my 150k mile origional oem one was still fine but its old plastic that id rather not risk. but still it lasted 15 years an 150k miles, who knows how long it would have held up.
Jump to top scoobiedoo2029 is offline   Reply With Quote
Old Tue, May-22-2012, 05:37:23 PM   #5
greyflyer
greyflyer's Avatar
Reputation: 0 greyflyer is on a distinguished road
Interesting because I was getting ready to do this job. My car only has 50k miles on it and the original pipe is in perfect condition, car stays nice and cool in traffic with the a/c on. What's the consensus, should I just keep my eye on it and leave it alone or take a preemptive strike and replace it with another factory pipe and the Stewart?
Jump to top greyflyer is offline   Reply With Quote
Old Tue, May-22-2012, 05:47:02 PM   #6
white-hot
is lurking around the corner
white-hot's Avatar
I have a "good" Ronak unit on the coupe, but when I just did the cooling system on the vert last week I went OE plastic. The first one lasted 14 years and 92k miles, so what is not to like. The primary issue with an older plastic unit is it cracks very easily when over torqued, something many shadetree types tend to do (that and waterpumps ), so always a good idea to replace when doing the cooling refresh.
Old Tue, May-22-2012, 05:58:11 PM   #7
cmcon98
cmcon98's Avatar
Reputation: 0 cmcon98 is on a distinguished road
I have a URO aluminum one on my vert. It's of crappy casting quality, but it doesn't leak after a year or so on the car. Next time I drain the cooling system for whatever reason, I'm replacing it with OEM plastic. They generally last 100,000 miles, so I don't know what I was thinking when I went with the aluminum one that looks like it was made in a factory in Bratislava.
'99 M3 'vert, 5-speed, cosmos/sandbeige, bone stock except Konis and speakers.
Jump to top cmcon98 is offline   Reply With Quote
Old Tue, May-22-2012, 06:07:12 PM   #8
MMMGP
retired
MMMGP's Avatar
Reputation: 0 MMMGP is on a distinguished road
Poland
Installed the Al one about 3 months ago, URO version, so far no leaks. Next time around I'll stick with OEM plastic.
'11 335is vert Alpine/Schwarz (1 of 168)
'12 X5 35i Premium Alpine/Schwarz (1 of thousands)
Jump to top MMMGP is offline   Reply With Quote
Old Tue, May-22-2012, 06:31:19 PM   #9
Jrrrrrrr
Unregistered User
Jrrrrrrr's Avatar
Another vote for the genuine BMW plastic housing.
Like all work with engine gasket surfaces and M6 bolts, tighten bolts evenly, use RTV as needed, and finish torquing carefully.
Old Tue, May-22-2012, 08:52:54 PM   #10
Brandon318
Reputation: 0 Brandon318 is on a distinguished road
There are three types of housings floating around out there. One, is the aluminum housing. These are cast poorly and leak often. I wrote a huge post about my personal experience with aluminum housings about five years ago. Use the search feature here and I'm sure you'll find it. Basically, I went through two poorly cast and leaky aluminum housings before switching back to composite over the course of a few months.
The next type is non-OEM plastic. These are crap too, often made in China. Nothing more needs to be said about these, just don't buy one.
The last type is the OEM composite housing. This is the OE, BMW, German-made good stuff that originally came on the car. It's very high-quality, robust "plastic". People complain about them cracking after about 80,000 miles. The solution here seems obvious to me: consider it a consumable part, much like the rest of the cooling system, and replace every 75,000 miles. Problem solved. Buy this at the dealership or through an online parts vendor; just make sure it has the little BMW stamp embossed inside.
See post #4... http://www.m3forum.net/m3forum/showt...mostat+housing
/// Brandon
Jump to top Brandon318 is offline   Reply With Quote
Discussing Aluminum vs Plastic Thermostat Housing in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
