Old Wed, Oct-03-2012, 04:24:07 PM   #31
Skyfire
Reputation: 0 Skyfire is on a distinguished road
Default Re: Wheel bearings
I've got a similar situation: clicking noise from the front while car is turning, and it's gradually getting worse. I can't seem to reproduce the noise on the lift since the system is not under load. Taking out the cover over the bearings, and I noticed this. Is this what a bearing gone bad looks like?
2003.5 TiAg/IR Vert
Jump to top Skyfire is offline   Reply With Quote
Old Thu, Oct-04-2012, 04:39:36 AM   #32
808elise
808elise's Avatar
Reputation: 0 808elise is on a distinguished road
Why not just add them to the list if you have over 50k miles on car? Seems like it should be something added to your maint list since you own this car and they are known for going out at around 50-60k.
-Josh
Jump to top 808elise is offline   Reply With Quote
Old Thu, Oct-04-2012, 04:49:56 AM   #33
50k is pretty early for wheel bearings. 100k would be more reasonable, but I've heard of them lasting quite a bit longer in many cases
Old Sat, Dec-08-2012, 09:35:52 AM   #34
ItsCoo2PYoPants
ItsCoo2PYoPants's Avatar
Reputation: 0 ItsCoo2PYoPants is on a distinguished road
i started getting a nasty ticking sound from my drivers side rear wheel when i got on the freeway today. wheel bearing?
Jump to top ItsCoo2PYoPants is offline   Reply With Quote
Old Sat, Dec-08-2012, 11:37:50 AM   #35
mzeed
Reputation: 0 mzeed is on a distinguished road
I think it is very important to remove the caliper in checking the wheel bearings as it allows better feedback on play and rotation. Also you can inspect the dust boots of the caliper ,best done with a flash light, as any tear or opening in the dust boot will cause corosion on the piston and thus a sticky caliper which may cause similar symptoms
Jump to top mzeed is offline   Reply With Quote
Old Sun, Dec-09-2012, 01:23:03 PM   #36
ItsCoo2PYoPants
does this sound like a bad wheel bearing? started ticking yesterday when i got on the freeway. its coming from the drivers side rear wheel. I havent had a chance to take it apart yet to look
Old Sun, Dec-09-2012, 03:02:50 PM   #37
28BMWM3
28BMWM3's Avatar
Reputation: 0 28BMWM3 is on a distinguished road
Can anyone help or provide me with advice on this thread? Ok so here goes, basically I used longer bolts on my new wheels, so long story short I need to replace both front dust plates and both abs sensors, now this means I need to remove/replace both wheel bearings??? Also 3 lights are on my dashboard, brake, traction, dsc? Is there a way around replacing all without removing bearings? Also what will this cost give or take????i would buy parts looking for labor cost?
Jump to top 28BMWM3 is offline   Reply With Quote
Old Wed, Sep-13-2017, 07:58:17 PM   #38
OneWheelPeel
OneWheelPeel's Avatar
Reputation: 0 OneWheelPeel is on a distinguished road
Originally Posted by AlpineEcstasy View Post
If you do need a new hub, buy the one that is made by F AG except no space between the F and the A (forum filter would block the brand name).
I picked one up last summer and it was good quality.
I work for the parent company to F AG as a mechanical engineer. The company, Schaeffler, is known worldwide for making bearings. In fact, they invented the first machine to perfectly polish a sphere (ball). Many E46 components are made by Schaeffler. look under the hook, the belt drive will have INA components. INA is the engine-components arm of Schaeffler (the arm I work for). It was pretty cool to pull up drawings and CAD of the replacement parts I'm putting on my car. I will always replace with F AG/INA/LUK components because I know what goes into them. Even if F AG wasn't the OE supplier its likely an upgrade. Similar to MOOG ball joints.
Jump to top OneWheelPeel is offline   Reply With Quote
bearings, wheel
Wheel bearings jacclark M3 Track: Racing and DE 6 Fri, Aug-24-2007 06:12:13 PM
Wheel bearings or...?? bfaskier Faults, Fixes and DIY 8 Wed, Jun-14-2006 11:08:24 PM
Groaning noise from front wheel. Wheel Bearings? Blue///M3 E36 M3 (1992-1999) 5 Sat, Jun-03-2006 03:28:53 AM
Wheel bearings johnj3nks E36 M3 (1992-1999) 3 Thu, Apr-21-2005 01:12:19 PM
Wheel bearings. 04E46 E46 M3 (2001-2006) 6 Thu, Feb-17-2005 12:24:54 PM
Discussing Wheel bearings in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
