Old Wed, Feb-10-2016, 07:29:09 PM   #281
buzz367
buzz367's Avatar
Reputation: 0 buzz367 is on a distinguished road
Default Re: e92 M3 mechanical issues...
Originally Posted by delirium45 View Post
Hey friends, i am considering buying a used, manual, E92, however, i was hoping to find a consolidated (relatively accurate) list of known issues for each production year.
Does this exist ?
I am not afraid of a little routine maint & manual work...
I'm looking for something similar... is this out there?
2008 E90 M3
Jump to top buzz367 is offline   Reply With Quote
Old Thu, Mar-03-2016, 11:19:34 PM   #282
amunoz94
amunoz94's Avatar
Reputation: 0 amunoz94 is on a distinguished road
Originally Posted by Swein1992 View Post
Hey guys I am new here. I just got my 2010 e92 M3 few weeks ago and I am really new to the vehicle. The car has 40000 miles on it and it is equipped with DCT. So I have had this problem recently. When I turn the steering wheel and release it at stationary, it will make a really annoying sound inside. It feels like the steering wheel is knocking something. I went to the dealer and they said the noise is from the release of tension and steering wheel going back to the place. I also notice that when I turn the steering wheel at stationary, the engine revs up and bounces between 600~1000 rpm. The dealer said its normal due to power steering gives load to the engine. Do your M3s act the same?
Nope mine does not do that.
Jump to top amunoz94 is offline   Reply With Quote
Old Wed, Aug-03-2016, 03:37:14 AM   #283
bmwfst1
bmwfst1's Avatar
Reputation: 0 bmwfst1 is on a distinguished road
I have a 2010 m3 with dct transmission. The car have 74xxx miles. I have had issues with the transmission. At around 50xxx miles I started getting dct warnings. The transmission would go into a safe mode where it would skip gears. The fault codes showed clutch 1 and 2 total failure. When I shut the car off and turned it back on the car ran fine. The transmission also shifts on its own sometimes. I give it throttle while driving and there is a delay then the car upshifts on its own. I had the gts software installed and it didn't solve anything. An indy shop told me I need new clutches because they are worn. But I have never had the transmission slip no matter how hard I accelerate. I think it could be the mechatronics unit. But idk.
The fault codes are
5a41 pressure sensor clutch 1 total failure
5a43 pressure sensor clutch 2 total failure
5a61 selector rod 1/3 fault.
Jump to top bmwfst1 is offline   Reply With Quote
Old Mon, Aug-22-2016, 02:39:53 PM   #284
V1VRV2
V1VRV2's Avatar
Reputation: 0 V1VRV2 is on a distinguished road
Valve cover gasket oil leak at 37,000. Only have 40,000 on it now. No other big issues. 2011 E93.
Jump to top V1VRV2 is offline   Reply With Quote
Old Wed, Oct-05-2016, 02:23:59 AM   #285
affemann2
Reputation: 0 affemann2 is on a distinguished road
Hi Everyone. I have 2008 E92 with 59k miles on it. Recently when I get on freeways, shift into 3rd or 4th and step down harder on the gas I get a service engine soon light and the car goes into limp mode. I usually take the next exit. Turn the engine off and on and then the service light soon and the limp mode go away. It's been temperamental where it happens consistently for a while and then it doesn't happen for 1-2 weeks. I have an Auto Link AL 319 and it registered P155E. I have tried to look this code up and it seems to be anywhere for a spark plug to a throttle actuator. The original owner of the car changed one of the spark plugs at 30k miles. Given that this only happens intermittently just trying to figure out what is going on before I go down for my service 2 in a couple of weeks. Thanks in advance for any info.
Jump to top affemann2 is offline   Reply With Quote
Old Wed, Oct-05-2016, 03:26:46 AM   #286
You need to read the codes or you are just guessing among a number of possibilities. My guess would be an actuator and that the problem will get worse.
Old Thu, Oct-06-2016, 02:03:48 AM   #287
61Panhead
Reputation: 0 61Panhead is on a distinguished road
I have a 2008 M3 with 53000 miles lost power with warning, I pulled over and shut the car off and turned it back on and the warning went away. But only for a week. I went to BMW service and have it checked out. It was the throttle actuators, one was bad and the other getting bad I had them both replaced. I did not have the time or knew how to do it. The service manager stated that it is a common problem at around 50,000 miles.
I am looking into getting a shop manual for future problems.
Jump to top 61Panhead is offline   Reply With Quote
Old Thu, Oct-06-2016, 07:15:23 PM   #288
affemann2
Just got back from mechanic. It was throttle actuator. He wants to replace both. Is it better to replace both? Is there a high likelihood that if one goes bad the other one is bad too? Or should I replace one?
Old Tue, Sep-12-2017, 09:10:59 AM   #289
diecast1269
Reputation: 0 diecast1269 is on a distinguished road
Hi everyone I just bought a 08 coupe m3 with 103k miles about 2 weeks ago, and since I bought it it was showing the oil max capacity warning light so I googled the issue and pretty much I ended up draining about 1 quart of oil like a lot of videos and m3 forums suggested to be done, so I drove the car for a couple of days (about 10 miles ) and the oil max capacity warning was still displaying, so then I ended up draining all the oil to measure the amount of oil in the engine i drained both oil sumps and to my surprise the stupid previous owner had about 13.5 quarts of oil in the engine, I found out that this motor only takes about 9.3 quarts so I refilled the engine with about 9 quarts and I have been driving the car for a week and I'm still getting the oil max capacity warning.
So my question now is do you guys think my car has a faulty oil sensor that I need to replace? Since I know I added less oil than required and still shows oil maximum capacity.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Jump to top diecast1269 is offline   Reply With Quote
Old Tue, Sep-12-2017, 05:37:04 PM   #290
Takes a bit of driving to get an accurate reading after an oil change. You might not be there yet. Also possible you did not get all the old oil out and are just a tiny bit over. You can add a real dipstick but it's not cheap.
e92, issues, mechanical
Mechanical Watches SteDevote Off Topic 10 Fri, Sep-19-2008 10:43:04 PM
Anyone concerned about major mechanical issues? jones205 E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) 13 Sun, Feb-17-2008 08:03:15 PM
Best mechanical pencil? ArtM3 Off Topic 42 Sat, Nov-04-2006 01:06:57 AM
NEED HELP with some mechanical know-how jddwyer E36 M3 (1992-1999) 2 Mon, Jan-10-2005 07:15:07 PM
OT: Mechanical Watches M3ForFun E46 M3 (2001-2006) 23 Sat, May-31-2003 05:03:19 PM
Discussing e92 M3 mechanical issues... in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
