Old Wed, Jul-12-2017, 04:05:35 PM   #21
DasBlitzAuto
Reputation: 0 DasBlitzAuto is on a distinguished road
Default Re: Lost Oil Pressure at track what now?
Originally Posted by ANT'S M3 View Post
If it were me I def would throw in a new pump, new oil, new oil filter & go from there. In any circumstance if the engine is hurt you would have wasted a weekend (i dont think thats half bad knowing for sure, you know?) and you would already have your new pump for you new engine since it will now be a no brainer to install that and secure the nut before installing the engine.
Alrighty thats a good plan, is the Achilles Upgraded pump a good choice? I'd also grab their baffle and upgraded tube. I did some reading on the VAC ones people don't seem to be too please with them.
1997 Estorilblau E36 M3
TCKR DA Suspension - Turner Sways - Active Autowerke Intake/Exhaust - 17x9 ARC8 - Hankook RS4 245/40/17 Square - UUC EVO Short Shifter - Kirk Rollbar - Sparco Evo 2s - MOMO Monte Carlo Wheel - Motion Motorsport Underpanel
Jump to top DasBlitzAuto is offline   Reply With Quote
Old Wed, Jul-12-2017, 08:15:21 PM   #22
kablammo
kablammo's Avatar
Reputation: 0 kablammo is on a distinguished road
Was the oil pump nut the culprit? Do you have an aftermarket flywheel?
Jump to top kablammo is offline   Reply With Quote
Old Mon, Jul-17-2017, 04:30:52 AM   #23
DasBlitzAuto
Finally got around to dropping the oil pan today. Nut did indeed spin off. Oil pan looked ok for the most part i think. A little bit of junk in there I don't know how much is normal for an engine with 105k on it.
Pump, tube and baffle should be here tomorrow. Also wanted to change the motor mount since I had the subframe down but looks like the Bimmerworld ones are out of stock
Nope stock flywheel
Old Mon, Jul-17-2017, 05:37:30 AM   #24
Nope stock flywheel
I have a set of the BW mounts with 500 miles on them. Ready to ship
Old Tue, Jul-25-2017, 10:58:53 PM   #25
DasBlitzAuto
Well got the car started today new oil pump, tube and baffle. When I first started it i swore it was blown but turned out to just be ALOT of lifter tap. Took the lifters a good 30 mins at idle to finally charge up and quiet down. Took it for a nice test ride still pulling strong looks like I got lucky
I did change the oil (obviously) and the filter, any ideas on when I should drop the oil again just to flush all the crap out? Plus I figure I will get this batch analyzed instead of the batch where I actually lost oil pressure, this one may tell me more?
P.S. everyone's help on this is much appreciated thanks for all the good advice so far!
Old Wed, Jul-26-2017, 01:12:29 PM   #26
ANT'S M3
FLIBIS!
ANT'S M3's Avatar
Reputation: 0 ANT'S M3 is on a distinguished road
Yes If it were me i would do another oil and filter change in about 40 miles for better piece of mind. (hope you buy your oil at Walmart where Mobil 1 is cheap)
As far as another oil sample, I don't know how useful it would be. It will basically tell you what you already know. I'm more than sure levels will be elevated but these stats will not determine how long this engine will last. As long as your on top of your oil changes I wouldn't be surprised if this engine outlasts your ownership of the car.
- E30 M3 -
Jump to top ANT'S M3 is offline   Reply With Quote
Discussing Lost Oil Pressure at track what now? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
