Old Wed, Jul-05-2017, 01:37:55 PM   #1
kyrix1st
kyrix1st's Avatar
Japan
Default Rear suspension needs to shut up
Hey guys, need some help with this issue.
There are three symptoms that need fixing:
1. Rear axle clunking on every rough road
2. Clicking sound when braking. (probably related to #1, heard around 0:22)
3. Squeak on bumps (think it's joints or lubes)
Replaced items: RTABs+limiter, lower ball joints (both left and right)
Suspects: Both axles, differential, diff/subframe bushing
Current problems:
-Poor corner-in (possibly rear struts as well?) but manageable corner-out. Front is rock solid. This could be fixed with some aggressive neg camber because I'm running basically stock.
-Bad front brakes (rotor needs replacing)
-Whenever I lift off the throttle, the car shakes back and forward(more than needed) like a raped ape.
Video:
Would be nice to hear your thoughts!
WTB: Carbon airbox
'98 M3 evo (S50B32)
Rear: Stock-Endless CC-RG //
Recaro SPG, SR-2//
Sparco 35cm steering//
Hella headlights//
Old Wed, Jul-05-2017, 01:53:24 PM   #2
kyrix1st
kyrix1st's Avatar
Japan
Default Re: Rear suspension needs to shut up
I would also share that this metallic clunking stops completely if I apply brakes while traveling forward, and the noise is only heard from the rear. It was just the left side at first but started to develop on the right side as well.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Recaro SPG, SR-2//
Hella headlights//
clunk, e36, rear axle, rear suspension, squeak
Discussing Rear suspension needs to shut up in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
