Old Tue, Jun-20-2017, 06:08:20 PM   #1
The Producer
The Producer's Avatar
Reputation: 0 The Producer is on a distinguished road
Default LTW Wing composition and repair q's
Hey guys - I know there are several resident experts here when it comes to LTW wings. Through good fortune I've acquired this broken one.
Any recommendations for repair before I simply drop off at a body shop and hope for the best? Westopher wondered of an aircraft structures shop might be the place to go. The breaks are very clean, and being the lower tray, I hope not really structural. There are a few shops like this out by the regional airport that I thought about dropping in to.
There is also one small corner of the upper wing that will need to be shaped from scratch - not sure what the best way would be to build up some material there that can be shaped back down.
Thoughts? I'm open to ideas
Thanks!
Ltw1 by GhstRidr, on Flickr
Jump to top The Producer is offline   Reply With Quote
Old Wed, Jun-21-2017, 06:20:47 AM   #2
westopher
westopher's Avatar
Default Re: LTW Wing composition and repair q's
JIM E????? BRAYMOND???? Where art thou?
I'm shining a BMW motorsport light in the sky over California.
98 m3, techno/anthrazit cloth, 103k and officially worthless.
Jump to top westopher is online now   Reply With Quote
Old Wed, Jun-21-2017, 09:25:27 PM   #3
Nate047
Nate047's Avatar
I'd be interested to hear thoughts on this, as I too have a damaged wing in my storage unit right now. I think it's a polyurethane mix. Boat repair shops might be an option, but I feel like if you find a top tier auto body shop, they should be able to handle it no sweat.
Old Fri, Jun-30-2017, 06:26:30 AM   #4
The Producer
hmm - thought I'd hear a little more on this subject.
going away for a couple of weeks, will hit some bodyshops on my return
Old Fri, Jun-30-2017, 08:30:43 PM   #5
englishtom1596q
englishtom1596q's Avatar
Can't see your pictures for some reason but a good aircraft repair place will have fiberglass/ carbon fiber skills. I've toured Duncan aviations facility and was amazed by the stuff they create
Old Fri, Jun-30-2017, 09:03:49 PM   #6
Dr Ed
Reputation: 0 Dr Ed is on a distinguished road
I have a damaged OEM LTW spoiler as well. Mine has several cracks on the base. My main concern is how the repaired wing will handle the impact of the trunk be opened and closed.
Jump to top Dr Ed is offline   Reply With Quote
Old Sat, Jul-01-2017, 05:05:34 AM   #7
The Producer
This is my concern too - trunks only going to get heavier (could get the upgraded trunk shocks)
Old Wed, Jul-12-2017, 11:01:05 PM   #8
E_Richt
Reputation: 0 E_Richt is on a distinguished road
The material appears to be a type of Polyurethane. The material on mine is, therefore I'm inclined to believe it is. The following is what my approach would be...
For bonding the breaks you want to use a cyanoacrylate. Other adhesives could be used with limited success, but would require softening the foam with a solvent which could (and will) damage the foam if not handled properly. See the below source for adhesive and tips.
http://www.permabond.com/materials_b...-polyurethane/
Now for building the corner of the top depends on how good you are with a Dremel. Buy some casting urethane (Shore 75), build a small "moat" around the area you want to build up, mix and pour the necessary amount of urethane, let dry, then finish with shaping to size. Sand to a smooth finish then cover with gel-coat. Sources for said materials are listed below:
http://www.fibreglast.com/product/ur...re-d/urethanes
http://www.fibreglast.com/product/wh...lyester_Resins
Jump to top E_Richt is offline   Reply With Quote
Old Wed, Jul-19-2017, 04:59:41 AM   #9
The Producer
^^ just got back from holidays and saw this informative reply ^^
thanks for posting the links - I'll do some more research.
Discussing LTW Wing composition and repair q's in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
