Old Mon, Jun-19-2017, 01:58:35 AM   #1
DasBlitzAuto
Reputation: 0 DasBlitzAuto is on a distinguished road
Default Oil Pressure Light with Liqui Moly at Track
Hey guys I'm very sorry to post another one of these but I couldn't find anything very recent about this last post i saw that was useful at all was back in 2009.
Anyhow I recently bought a 97 M3 as a track car it has 104k on the clock. This past weekend I was running at NJMP and noticed by oil pressure light flickering at idle after a session, as well as lifter tick. I tapped the gas a little light goes away. Then I can turn it off and start it back up a few mins later no lights no ticking. Im running Liqui Moly 5w40 the outside temps were 84 degrees Water temp was @ 214.
I know this can be normal on these cars but I just figured I'd ask if I should be running heavier oil for the track or if anyone else has these issues with the Liqui Moly oil.
Thanks in Advance!!!
1997 Estorilblau E36 M3
TCKR Suspension - Turner Sways - Active Autowerke Intake/Exhaust - 17x9 ARC8 - Hankook RS4 245/40/17 Square - UUC EVO Short Shifter
Jump to top DasBlitzAuto is offline   Reply With Quote
Old Mon, Jun-19-2017, 03:43:08 AM   #2
deboM3
Reputation: 0 deboM3 is on a distinguished road
Default Re: Oil Pressure Light with Liqui Moly at Track
I had a similar issue with 5w30. I switched to 15w50 and havnt seen the light since! I believe it's due to worn bearing clearances and the thinner oil doesn't keep the pressure up when the temp increases. Mine would only flicker at idle on super hot days and driving hard. I've driven probably 100k since I had the issue after switching oil so I wouldn't panic or anything.
Jump to top deboM3 is offline   Reply With Quote
Old Mon, Jun-19-2017, 04:18:09 AM   #3
mewantkouki
Reputation: 0 mewantkouki is on a distinguished road
My car had the flicker when I got it. I changed out the oil pressure switch and I haven't had any issues since. Hopefully it's something simple. The best way to get an idea of what's really going on in the oiling system would be with an aftermarket gauge.
Jump to top mewantkouki is offline   Reply With Quote
Old Mon, Jun-19-2017, 04:41:16 AM   #4
deboM3
Second this! Forgot to mention my oil pressure was around 5-7 Psig when the light was flickering measured on an electronic vdo gauge. Since switching oils it's around 10 always, even when it's Uber hot and after driving hard.
Old Mon, Jun-19-2017, 06:08:02 AM   #5
in4lee
Reputation: 0 in4lee is on a distinguished road
I run 15w-50 and have the same issue. However I replaced the oil pressure switch and the issue remains. Next thing might be a crack in the oil pick up tube which can be replaced with the z3 one offering more reinforcement.
Jump to top in4lee is offline   Reply With Quote
Old Mon, Jun-19-2017, 07:25:59 PM   #6
DasBlitzAuto
Thanks for the replies guys!! Would you say Mobil 1 would be a good choice to throw some 15w-50 in there?
Ill also look into getting a gauge and replacing the switch.
Thanks again guys!!!
Old Mon, Jun-19-2017, 08:20:41 PM   #7
Nate047
Nate047's Avatar
I have had a similar issue. Only occurs when the motor is fully warm and if the oil level is slightly low. Previous owners put 5w30 in the car it's whole life, I bought the car with about 122,xxx miles. I replaced the pressure sender, oil pump, pick up tube, added 15w40 Liqui Moly and still had the problem. Went to 15w50 on my last oil change and have not yet seen the light flicker. Did a Blackstone Labs analysis, shows low likelihood of worn bearings. If the light shows up again, the oil filter housing is the last thing I'll replace before looking at rod bearings.
Old Tue, Jun-20-2017, 01:11:00 AM   #8
DasBlitzAuto
Seems like 15w-50 is the way to go first then. Ill go pick some up and I guess Ill see what happens at the next HPDE.
Old Tue, Jun-20-2017, 02:30:31 PM   #9
kyrix1st
kyrix1st's Avatar
Japan
I don't know much about US spec M3s, but it could be the following:
1. Oil pressure sensor malfunction: It has to hit 0.8 bar or so for the light to flicker. High chance.
2. Oil pump failure: Not complete, but weak.
3. Oil pressure relief valve not closing: Typically happens at high rpm but not at idle.
4. bearing clearance: Will also drink your oil since it gets through the valve.
5. Oil shearing: Unlikely, but if you use crappy group II oil or regular group III oil at the track, this will happen. I used shell ultra helix 5w-40 before, and after 30 laps the engine started to make ticking noise. Changed to redline 5w-40 (group IV&V); I have no engine noise and no viscosity change after 4,000km of hard driving.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Rear: Stock-Endless CC-RG //
Recaro SPG, SR-2//
Sparco 35cm steering//
Hella headlights//
Old Fri, Jun-23-2017, 04:57:09 AM   #10
MaynardZed
MaynardZed's Avatar
Reputation: 0 MaynardZed is on a distinguished road
Normal.
I run 20-50 amsoil race oil and still get that after hard run session. As long as it goes away as soon as throttle blip it's fine.
Just make sure your track car:
1) has oil pump nut secured via weld or wire
2) oil pan baffles e.g. Vac or Turner
3) Do not overheat head. Cooling system must be top notch
4) Do not over rev / float valves
1999 BMW E36 M3
Ground Control Race Suspension
Full Cage - Flatout Motorworks
OMP Full Containment Race Seat
S52 with bolt ons 237 rwhp (DynoJet)
2600lbs empty
Jump to top MaynardZed is offline   Reply With Quote
Discussing Oil Pressure Light with Liqui Moly at Track in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
