Old Sun, Jun-25-2017, 10:57:10 PM   #31
mewantkouki
Reputation: 0 mewantkouki is on a distinguished road
Default Re: New to me 95 M3
Originally Posted by NolliM3 View Post
Have you installed the power steering kit yet...dying to get feedback since it's so pricey; however, I am seriously thinking to go that route than trying to weld the connectors?
I should be doing that fairly soon actually. I need to buy an aluminum spacer and some hardware to mount the reservoir. I'm going to use riv-nuts so it makes for a nice clean install. The kit from bimmerworld is pretty pricey but after pricing it out using comparable power steering hose and compression fittings it worked out to be a few dollars less also have to factor in the cost of having an -AN fitting welded onto the power steering cooler unless you can braze it yourself. The Moroso reservoir it comes with costs $100 by itself too...
Jump to top mewantkouki is offline   Reply With Quote
Old Fri, Jul-07-2017, 08:01:26 AM   #32
mewantkouki
Well... First off, **** you photobucket.
Update: Ordered fortune auto 500's, new front lower control arms, SPC rear camber arms, and front and rear strut reinforcement plates.
I still need to buy new front lower control arm bushings (lollipops) Does anybody know of a lemforder set that come pre-pressed..? I am trying to keep this easy as I don't have easy access to a shop press. I need the offset bushings. PN: 31129064875
Discussing New to me 95 M3 in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
