Old Sun, Oct-09-2016, 04:23:34 PM   #11
Shockerg1
Old skool BMW lover
Reputation: 0 Shockerg1 is on a distinguished road
United Arab Emirates
Default Re: New m3 and rod bearings
And here is all 8
As you can see , top halfs are pretty worn on all evenly, which is pretty normal wear & tear at 127k km... From the lower ones, they were ok except for Cylinder 1 & 2 which were on their way out , so its good that i changed them when i did. Overall was expecting worse wear like the others i have seen.
Jump to top Shockerg1 is offline   Reply With Quote
Old Mon, Oct-10-2016, 04:35:57 AM   #12
admranger
Registered troublemaker
I'm hoping to do mine this weekend with BE Bearings and ARP bolts.
'11 E90 M3, Melbourne/Black/Fox Red/Black, 6MT, roof, PP2, heated seats, Eibach Pro Kit, GC Street camber plates, Arc-8's, Technic harness, JL XD 600/6
Old Fri, Oct-14-2016, 03:25:06 AM   #13
///MonkeyTech
Reputation: 0 ///MonkeyTech is on a distinguished road
Rather safe than sorry on the rod bearings, BUT to be honest with you, you could be hearing lifter tick also. Not that I would avoid doing rod bearings, I would
Jump to top ///MonkeyTech is offline   Reply With Quote
Old Fri, Oct-14-2016, 08:34:50 PM   #14
PRYDEREI
PRYDEREI's Avatar
Reputation: 0 PRYDEREI is on a distinguished road
sold my e46 m3 a while ago but am considering an 11 m3 now and I came here to search the rod bearings so thanks for your thread it was right at the top
Does anyone mind sharing briefly how easy the DIY is for rod bearings? Need to pull the motor out or can it be done in car like on the e46? I want to read up on the job but am not worried about my DIY capabilities but would prefer to do this during the summer and winter is coming (have 2 other cars inside the garage atm)
Jump to top PRYDEREI is offline   Reply With Quote
Old Sat, Oct-15-2016, 05:37:14 AM   #15
In the car. Lower subframe and let it hang on the suspension. Figure on 12 hours if you have not done it before. I think it could be done in 8.
Old Sat, Oct-15-2016, 07:32:22 AM   #16
Shockerg1
Old skool BMW lover
12 hours is spot on!
Old Sat, Oct-15-2016, 07:46:52 AM   #17
///MonkeyTech
I did one at home last month. Here's a good tip. After you drop the oil pan, let it sit there and drip off for a day
Old Mon, Oct-17-2016, 08:26:49 PM   #18
admranger
I'd agree with the 12 hour estimate. I have a lift and it was still a pain to do.
Don't forget to remove the sway bar links and the steering coupler when you drop the subframe. Gives you the extra room you need.
Here's some pics. 35k miles on the bearings. Oil sent in to Blackstone to see what they say.
Sorry for the hosting service box in them...
What causes the spots? They were on a few shells, but not all...
Old Tue, Oct-18-2016, 01:28:25 PM   #19
These are the newer lead free bearings found on 2010-2011 and newer models. I am not sure how to judge wear on them. With the lead based bearings it is easier since you see copper when you have worn through.
Old Tue, Oct-18-2016, 10:59:59 PM   #20
admranger
I agree. They don't look good to my untrained eye. Wonder what a Clevite rep would say?
rod bearings
Discussing New m3 and rod bearings in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
